hydraulic clutch line problems
Old May 31, 2015 | 02:51 PM
jdub2178's Avatar
jdub2178
I was replacing the clutch in my '89 f-150 with the standard Mazda m50d transmission and the hydraulic line was split right at the fitting that goes into the slave cylinder! I had enough slack to cut it and stick it back on, but the plastic line is extremely tight and I can't seem to force it on the fitting! Is there a special tool to help me push the plastic line onto the fitting or do I just need to man up and push it harder? Or is it impossible and the whole thing need to be replaced?
Old Jun 2, 2015 | 04:49 AM
EPNCSU2006's Avatar
EPNCSU2006
Try hitting the end of the tube with a hair dryer. Heat may soften it enough to slip it over the fitting. I've never worked on this fitting so I have no idea if there is a special tool or anything like that.
velcro7279
1983 - 2012 Ranger & B-Series
Aug 16, 2010 04:37 AM
thedoctor
Sep 4, 2009 09:36 PM
Mow4YourMoney
Nov 27, 2006 07:03 AM
kij2004
Jun 3, 2005 11:09 AM
Steele1
Nov 20, 2003 04:18 PM
