King Ranch LCD screen ?
Old May 30, 2015 | 04:38 PM
DOUBLEJACK's Avatar
DOUBLEJACK
Just bought my wife a new Super Crew F 150 King Ranch with everything on board. During the shopping process I also looked at a Lariat Super Duty with Nav and it had an aux input for video. The King Ranch F 150 has usb inputs but no video inputs. If I connect to the ports, the system looks for audio files. I would really like the video input because I run camera feeds from a horse trailer she pulls so she can see behind the trailer and inside the trailer when she is hooked up. Is there anyway to feed video thru the usb ports to the screen?
Old May 30, 2015 | 09:22 PM
Gary Lewis's Avatar
Gary Lewis
Page 441 of the owner's manual says you can play video from a device connected via USB. However, that device is expected to be a smartphone or somesuch, although I guess it is possible for a camera to be set up to look like a smartphone. In any event, it says you cannot play videos while the vehicle is in motion.
Old May 31, 2015 | 08:22 AM
DOUBLEJACK's Avatar
DOUBLEJACK
Thanks for the reply, I am going to try a usb camera and see what happens.
Old May 31, 2015 | 08:35 AM
Gary Lewis's Avatar
Gary Lewis
Good luck, and let us know how it goes.
Old May 31, 2015 | 02:38 PM
DOUBLEJACK's Avatar
DOUBLEJACK
I plugged a USB web cam into the port and it didn't identify that anything was hooked up. More research is in order. On her 08' Lariat, I ran all new wire and a 7" screen mounted on the visor. I can do that again, it just seems like such a waste being everything is already in place except the input connection.
Old May 31, 2015 | 03:00 PM
Gary Lewis's Avatar
Gary Lewis
Even if you get it to work via USB it'll quit when you shift into gear. So, the add-on may be best.
Old Jun 1, 2015 | 08:20 AM
MNRanch's Avatar
MNRanch
I believe that the lockpic Air might be able to do what you want especially if you don't have the 360 CAM.
Old Jun 1, 2015 | 09:18 AM
1956MarkII's Avatar
1956MarkII
I've seen bluetooth backup cameras on the market: the monitor looks like a GPS, uses bluetooth to create the connection between camera and monitor. Not sure about the range, but I would think it would work from the back of the trailer to inside the cab.
EpicCowlick
Mar 23, 2018 04:32 PM
SmokyOkie
Mar 19, 2018 07:07 PM
MC_Greenmachine
2015 - 2020 F150
Jan 30, 2017 08:36 PM
lo
All Things Towing
Jun 18, 2012 03:11 AM
JEB70
Feb 7, 2009 10:31 PM
