ATF coating headers
Old May 30, 2015 | 12:21 PM
chiefsfootball's Avatar
chiefsfootball
I know the ff391 is technically for full size cars but wouldn't they still work since they are shorties? They look even shorter than ff427s
Old May 30, 2015 | 12:29 PM
qman's Avatar
qman
Originally Posted by chiefsfootball
Did you mean to say "Peyton Manning fan here"... haha sorry had to... I'm done
No . . . and hell no. Can't stand when he pouts.
Old May 30, 2015 | 12:32 PM
bajafishnut's Avatar
bajafishnut
Remember to check the tubing thickness... most on the internet are 18 ga. not 16. A few are. I am thinking that the 16 ga will last a lot longer..??
Baja
Old May 30, 2015 | 03:35 PM
HIO Silver's Avatar
HIO Silver
They might could... but I sure as heck wouldn't ask the seller since he's trying to sell them ya know?
Old May 31, 2015 | 08:48 AM
chiefsfootball
Oh yeah! I wouldn't ask him. That's just a good price for some sandersons and it'd be nice if they would work well. There is a used pair and a brand new pair. Problem is, I'm stuck with em if they don't fit bc they don't accept returns... guess I could hold on to them for a future FE car
Old May 31, 2015 | 01:11 PM
orich's Avatar
orich
Another ol skool trick is a blast from the past is dry spray on graphite when prep good can stop rust for many yrs of time.
Ford even used a graphite grease on the exhaust manifold heat-shields as a sealer that is still available @ Amazon
Many guys called them gaskets tho. and just use what comes in a gasket set that all fail in a short time.
And with the high failure rate of exh. manifold gaskets many guys keep trying to find a exh. manifold gaskets that won't fail, all with out using locking washers/bolts.
Orich
Old Jun 2, 2015 | 07:15 PM
chiefsfootball
Does anyone know if the stock 427 cast iron headers will fit a 4x4 truck? Bc I found a set and I'd like to have those if he's willing to let go of them for a decent price.
Old Jun 2, 2015 | 07:31 PM
orich's Avatar
orich
Does anyone know if the stock 427 cast iron headers will fit a 4x4 truck? Bc I found a set and I'd like to have those if he's willing to let go of them for them decent price.
I rem ember a guy installed a pair some yrs back but needed to cut the frame notch for clearance issues.
But their is two different sizes, short & long tube and don't remember if the guy said or not..
I'm not willing to butcher up my frame just for headers. And going off road may crack them any way.
Orich
Old Jun 2, 2015 | 07:38 PM
chiefsfootball
Orich
Yeah no way I would cut my frame for that.
Old Jun 3, 2015 | 07:15 AM
f100today's Avatar
f100today
Orich
There is a manifold gasket that won't fail. Copper high temp RTV. Racers have been doing it for years. I had it on my BBF for probably 5 years with no problems. Throw the gaskets in the trash.
Old Jul 8, 2015 | 11:14 PM
chiefsfootball
Haven't posted on this thread in a while, but anybody ever try olive oil on their headers? Same principle as ATF I suppose but I know we use it to cure cast iron skillets and maybe it'd work for headers too?
Old Jul 10, 2015 | 01:00 PM
bajafishnut
I let my Clifford Performance headers get a fine rust scale, and then sprayed them with rust converter which is nothing more than phosphoric acid 10% solution. It turns the rust black, and forms ferric iron, out of the ferrous iron. Stops the rust for awhile... but here in Baja, the local's say, that even plastic rusts...
Baja
Old Jul 10, 2015 | 03:13 PM
  #28
orich's Avatar
orich
Graphite sprayed onto the exhaust manifolds was an old skool trick. well that was a trip
I never tried it but suppose to bake on an form a long lasting cast iron look coating.
Orich
Old Jul 12, 2015 | 04:20 PM
  #29
chiefsfootball
I ended up getting the sanderson ff427 and doing ATF. looks good. Just curious though, the nub I guess on the end of my starter touches the headers. So I can't take it off without removing my passender header. And with it just touching that end piece, will it cook my starter?
Old Jul 12, 2015 | 09:56 PM
  #30
orich's Avatar
orich
I broth this up on HIO thread that their was no way in hell to remove them but he figured he could do it with only having the 1/8" of gap.
But I could hardly work a heat blanket between the starter bush end dome & the header pipe mini is. I advised many guys when going to Sanderson to get a mini starter but few took my word for it.
Back in the 60's 70's we did not have cheap like todays mini starter so co's did make some headers that would not trap the starter. But today no reason not to have one.
I think I paid $129 free shipping
Orich
