Need flywheel replacement help
Old May 27, 2015 | 07:50 AM
candoo's Avatar
candoo
1966 F350,352,NP435. I have been unsucessful trying to get a replacement flywheel to replace the stock unit. Ring gear is bad and face is less than perfect. Going to put in a center force 11 inch clutch an cannot find a replacement fly wheel with 184 tooth ring gear. Have a NAPA in town but the kids at the desk are not helpful. Anyone have a Napa number or alternative I can utilize in Canada. I will replace ring gear and surface clutch if required but prefer new.
Old May 27, 2015 | 08:17 AM
bphirt1's Avatar
bphirt1
Hello. I just replaced mine with 352 this weekend. I was able to finally find one through Summit. It was $460.00. Ebay was selling useds ones for around $400. Worth the extra $60 for new one.
Old May 27, 2015 | 08:20 AM
candoo's Avatar
candoo
Price is way out of my buget. Center force has replacements for around the same price as well. I can refurbish for around $150.
Old May 27, 2015 | 08:23 AM
candoo's Avatar
candoo
I am also looking for a pilot bearing number...thanks
Old May 27, 2015 | 08:30 AM
bphirt1's Avatar
bphirt1
Mine had to be replaced due to million of stress cracks. No pilot bearing. It is actually pilot bushing. Any auto parts store should be able to order it.
Old May 27, 2015 | 10:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford part numbers for reference only - all are obsolete - but are available NOS
C5AZ-6375-K .. 352/360 Flywheel-Use with 11" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle.
1965/67 Galaxie/LTD 352 / 1965/67 F100/350 352 / 1968/76 F100/350 360.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
PEROGIE ENTERPRISES in Highstown NJ has 3 = 609-448-5593.
C5AZ-6375-L .. 390 Flywheel-Use with 11 1/2" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle.
1965/71 Galaxie/LTD 390 / 1968/76 F100/350 390.
PEROGIE ENTERPRISES has 4.
GREEN SALES CO. in Cincinnati OH has 14 = 513-731-3304 / 800-543-4959.
C5AZ-6384-A .. Flywheel Ring Gear-184T ~ Same applications as all of the above.
MILLER OBSOLETE PARTS has 1.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 29 = 704-786-8139 / 800-476-9653.
Note:
B8A-7600-A .. 1958/70 Bronze FE Pilot Bushing: 1.8509"/1.8525" O.D. x .6715"/.6725" I.D. x .495"/.505" thickness / Replaced by FoMoCo in 1971 with...
D1TZ-7600-A .. Needle Bearing: 1 27/32" O.D. x 43/64" I.D.
Tell the NAPA parts clucks to look in their paper parts catalogs (usually stashed under the counter), as this info may not be in their computers.
JosephMcCredie
May 13, 2017 05:15 PM
chapinmesa
Feb 28, 2008 08:47 AM
hdbloodtrail
Feb 19, 2006 05:04 PM
sniperscoutwill
Nov 25, 2003 04:07 PM
