F250 2wd Front Shocks 69' or 70'?
Is there any difference in the mounting of the front shocks for a 1969 F250 vs a 1970? I'm looking for heavy duty 3" extended shocks for my 69' but the only listings I can find for 2wd and 3" lift start at 1970. For 4wd it's usually listed for 66' to 79'. I was under the impression that 69-73 2wd were mostly the same. Please correct me if I've got this wrong.
Thanks.
Thanks.
Yes, but I have way too many irons in the fire and wanted to minimize the time I spent finding shocks with the right ends, Length and damping rate, for my application. It does make things faster if the manufacturer has done that work already. That way it should bolt right up with only a few hours of machining, welding and cursing (like all bolt on parts) .
on
Don't complain about the manufacturer not testing shocks as it would raise the costs to test all the many possible combinations out there, and everyone's truck is different. Each truck has different rated springs used. Do what the Class 8 racers do to find the correct shock length: put the front end up on jackstands and let the suspension droop down full length. Measure center to center of the shock mounts. Now put a jack under each I-beam and raise the beam so the suspension is at full compression, and now measure again. This is the parameters of shock length that you have to work within. Valving is up to you because it depends on the type of driving you want to do. And don't forget limiting straps to prevent something from coming undone at full droop.
Kudofo
1983 - 2012 Ranger & B-Series
02-05-2012 09:16 PM
oldjag
07-20-2010 09:41 PM
paubreadly
03-22-2006 11:03 AM
