Brake troubles
Old May 11, 2015 | 06:21 PM
351Cleveland C4's Avatar
351Cleveland C4
Brake troubles
Having a little bit of trouble with my rear brakes on the F100. The adjuster arm is not engaging on the star wheel, and I think the brakes are backing off because of it. I've taking them apart and made sure everything is how it is supposed to be. and everything is as how it is shown in the Chiltons manual. So I'm not sure what's wrong.
Any insight? They work great otherwise
Old May 11, 2015 | 06:25 PM
Gembone's Avatar
Gembone
get some pics so we might be able to see what's up
Old May 11, 2015 | 06:27 PM
JEFFFAFA's Avatar
JEFFFAFA
I can't imagine how the arm isn't touching the star wheel. Did you snap any pics?
Old May 11, 2015 | 06:44 PM
tasboj's Avatar
tasboj
I did my rear brakes on my 250, and the adjuster star would not engage, then a knowrest the adjuster screw was backwards, I turned it around and it engaged the arm and all was good. hope this helps.
TASBOJ....................................
Old May 11, 2015 | 07:02 PM
351Cleveland C4
I don't have pictures. And I already put it all back together so...
All the springs and hardware are correctly installed. The adjuster arm just is not holding the star wheel. It sits off of it a little. I thought it was supposed to be engaged all the time to keep the star from backing off.
Old May 11, 2015 | 07:20 PM
JEFFFAFA's Avatar
JEFFFAFA
If that small cable is stretched the lever might be kinda past the star wheel. Or if it's the wrong (aftermarket) cable it might be too short. The Ford number on the lever and cable kit was C8TZ2A176F. Discontinued but there are a bunch of them out of state.
Old May 11, 2015 | 08:03 PM
351Cleveland C4
I think the geometry is about right. But it sits out towards the drum.
I was thinking, and maybe if I flipped the bottom spring around to the inside of the shoe, it might pull the arm over a bit?
Old May 12, 2015 | 01:32 AM
tasboj's Avatar
tasboj
What you are describing is exactly the same situation I had, switch the adjuster screw end to end and the star should engage the adjuster arm, keeping it from turning loose.
Old May 12, 2015 | 07:50 AM
Tedster9's Avatar
Tedster9
This close? Everything should be nice and taut, the lever arm prevents the star wheel from loosening. Let us know what you find.
Old May 12, 2015 | 07:12 PM
351Cleveland C4
That is exactly how it is. But the arm is sitting OUT towards the drum away from the backing plate, and not engaging the star wheel.
I don't see how flipping the adjusters end-end would change anything, except they would be backwards and not right. Then it really wouldn't even have a chance of working.
Old May 12, 2015 | 08:02 PM
Tedster9's Avatar
Tedster9
Well there are right and left hand adjuster levers too, as well as right and left hand star adjuster links. Note that the illustration shows a left hand (drivers) side brake assembly. Something isn't seated fully, maybe backing plate is bent, or there is a wrong part installed etc.
The adjuster lever always fits in one of the teeth or just south of it anyway at the center line. When the brakes are applied backing up, and there is a bit of wear on the linings the lever gets pulled up and when the brakes are released the spring tension pulls the lever back down and the star adjuster is moved one (1) click in the tightening direction. It has to have contact with the adjuster at all times to work correctly and keep the brake adjuster from loosening as well
Old May 12, 2015 | 08:11 PM
351Cleveland C4
^Right, and that's what isn't happening. The stars arnt being engaged and are slowly backing off because of it. It's annoying as heck.
Old May 12, 2015 | 09:39 PM
Tedster9's Avatar
Tedster9
How about a pic? It won't take that long. We'll drink beer while you work.
Old May 12, 2015 | 09:56 PM
orich's Avatar
orich
May be not the same as yours since mine is f250 but close.
orich
Old May 13, 2015 | 10:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/67 F100's use a different cable (2A178) and levers (2A176/2A177) than 1968/79 F100 & 1975/79 F150.
