what water pump
Old May 26, 2015 | 06:52 PM
69issofine's Avatar
69issofine
what water pump
67 f-250 with a 300 out of a 91 original 67 water pump on the engine,it runs backward for the 91 but has the v-belt. where can i get the right pump for the 91 and have a v-belt? or do i change the harmonic balancer and alternator to a flat belt? i am at a quantry what should i do.
Old May 26, 2015 | 06:59 PM
gangstakr's Avatar
gangstakr
I think you have to turn the engine around.
Old May 26, 2015 | 08:07 PM
69issofine's Avatar
69issofine
well it turn over ok just can't get it to turn around.
Old May 27, 2015 | 09:07 AM
Gembone's Avatar
Gembone
You should post in the inline 6 section. You can get more people with direct knowledge there. Not enough coffee for me yet this morning to wrap my head around what you are asking. If you are using v-belts then you use the older 67 style pump, and the newer pump with serp belt. I believe that is how it works. since the fan on the pump will be finned to turn with the direction of rotation.
You could have a head gasket issue or years of crap in the block.
Old May 27, 2015 | 10:10 AM
qman's Avatar
qman
why did you put a 67 water pump on a 91 engine? why not put a 91 water pump on a 91 engine?
Old May 27, 2015 | 10:33 AM
Gembone's Avatar
Gembone
he would have to stick with serp belt if he did that. Most likely all his other pulleys are v-belt. the 2 have different rotations due to belt routing.
Old May 27, 2015 | 11:33 AM
ultraranger's Avatar
ultraranger
Originally Posted by 69issofine
67 f-250 with a 300 out of a 91 original 67 water pump on the engine,it runs backward for the 91 but has the v-belt. where can i get the right pump for the 91 and have a v-belt? or do i change the harmonic balancer and alternator to a flat belt? i am at a quandry what should i do.
The 4.9L (fuel injected 300) was produced from 1987-1996. It had a reverse (counter clock-wise) rotation water pump --with the serpentine belt setup.
If you currently have changed to a V-belt and a pre-EFI 4.9L water pump on the engine, it should be turning in the right direction (clock-wise rotation), as viewed looking at the engine from the front.
filthy6
24
Nov 5, 2015 06:06 PM
Joe19
1997 - 2003 F150
Nov 2, 2015 10:11 AM
money pit 69
Nov 29, 2014 12:26 PM
wolff7.3
Oct 12, 2014 05:52 PM
4sabre
Nov 29, 2010 03:54 PM
