updated obd
Old May 26, 2015 | 02:51 PM
jle70's Avatar
jle70
updated obd
Last Thursday I had Ford garage update my 95(94.5) obd2, to a 96. Now I can connect and read data. Although, when running live data, the engine dies, and will restart. This only happens when connected. I big thing I noticed after upgrade, idle is nice and smooth.
Anyone else have the engine issue while connected with scanner?
Old May 26, 2015 | 04:38 PM
madpogue's Avatar
madpogue
What device are you using?
Old May 26, 2015 | 06:59 PM
echo95's Avatar
echo95
You can't pull codes with the engine running to my knowledge. That is usually done with key on and engine off. You should be able to get real time info such as ICP and IPR duty cycle along with boost and injector pulse width.
Maybe with AE or scan gauge that can be done, but those who use those systems will have to speak to that. I use the Torque Pro app on my smart phone, and am happy with that for now.
Old May 26, 2015 | 08:05 PM
fordpride's Avatar
fordpride
If engine dies when scanner is activated then the scanner isn't compatible or you're using the wrong platform
Old May 26, 2015 | 10:32 PM
oldbird1965's Avatar
oldbird1965
My scangauge can reset codes running down the road a 70mph.
Broncoseth
1978 - 1996 Big Bronco
Apr 3, 2015 09:24 AM
bsigg
Dec 8, 2014 09:27 AM
Murph2006
15
Dec 13, 2013 11:14 PM
rdsjw967
Jul 4, 2012 06:59 PM
srpsdf250
Feb 22, 2004 08:37 AM
