Obd Ii
Old Feb 21, 2004 | 05:36 PM
srpsdf250's Avatar
srpsdf250
Obd Ii
When I plug in an OBD II scanner to read the codes it reports that none were read and then shuts down the engine. Is the shutdown normal?
Thanks
Steve
Old Feb 21, 2004 | 09:49 PM
Paarrothead's Avatar
Paarrothead
What brand of reader are you using?
Normally, you take OBD 2 readings in the "KOEO" mode, key on, engine OFF. Why are you doing it with the engine running?
Old Feb 22, 2004 | 08:08 AM
79CEEJAY's Avatar
79CEEJAY
I agree, try to read your codes with the engine OFF.
Old Feb 22, 2004 | 08:33 AM
srpsdf250's Avatar
srpsdf250
Actron CP9135. Manual says it can read codes either KOEO OR KOER but with engine off it gets an error.
Old Feb 22, 2004 | 08:37 AM
luckild's Avatar
luckild
What code did you get?
