Engine swap options
Old May 26, 2015 | 07:16 AM
mythbustingpyro's Avatar
mythbustingpyro
Engine swap options
I've decided to swap the engine out on my 82 F100 flairside. It currently has an engine from a 76 in it that a PO swapped (4.9 inline 6). I would like to replace it with another inline, what year models will be the most straight forward? Looking to stay around $500.
Old May 26, 2015 | 08:45 AM
ctubutis's Avatar
ctubutis
Another good place to ask that question is here:
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
Old May 26, 2015 | 12:51 PM
mythbustingpyro
Thanks, I posted there, also if anyone knows, would it be possible to drop my flareside bed in place of a straight side and what that would take, would it be easier than an engine swap? Just trying to consider all my options.
Old May 26, 2015 | 01:50 PM
BTFordGuy302's Avatar
BTFordGuy302
If it bolts into the frame the same way I don't see why not, take some measurements and draw a diagram of where your bolts are located and compare it to where the bolts are located on a straight side, I'm sure someone on here would be willing to take some measurements on theirs. Swapping beds is not a hard process at all, it only took me about an hour to get mine off with some help from my friends! All you need is a few people to help you left the beds on and off! Why do you want to switch to a straight side? I love the look of the flare side pickups personally
Old May 26, 2015 | 05:33 PM
maytag906's Avatar
maytag906
Just curious, what's wrong with the old powerplant?
Old May 28, 2015 | 01:00 AM
mythbustingpyro
I wanna keep the flareside, but only can find straightsides for sale around me, so if I found one that ran decent with a good cab I could just drop my bed on it.
And the engine has a bad head from being extremely hot way too often ( was my only vehicle and I didn't have money to fix the head gasket at the time). It was so warped that it was going to take ~40 thousandths of shaving to bring it flat, but it ended up being cracked with a giant chunk missing from inside an exhaust port, which ended up cracking the exhaust too. It still ran and drove until the day I pulled the head off though. Just would hydrolock orboverheat if I drove it longer than 15 minutes.
So for the cost of another head and exhaust I can find a used engine or whole nother truck essentially, since my lower end probably isn't in the best shape anyways.
Old May 28, 2015 | 01:34 AM
BTFordGuy302
Ah ok I Gotchya, surprised that happened, I was always under the impression that the straight 6s were tanks, if you live anywhere near butler pennsylvania there's a HUGE yard of bullnose's most of which have the 6s, there's at least 150 trucks there. I live a decent distance from it but it's always worth a drive!
DSLPOWR
Apr 3, 2019 09:34 PM
tomohara
Sep 17, 2016 07:07 PM
Citizenrain
Mar 30, 2012 10:51 AM
cpetersen
Feb 12, 2011 07:53 PM
dono
1983 - 2012 Ranger & B-Series
Apr 17, 2002 11:13 PM
