Transmission Code
Old Sep 4, 2001 | 10:56 AM
getu12's Avatar
getu12
Transmission Code
I need to know what transmission is in a 1987 Ford F-250 302 EFI with a transmission code of "K" . My local Ford dealer tells me that the truck is too old for him to research it. I don't have the truck here at the present time to identify the trans. Thanks.
Old Sep 4, 2001 | 10:41 PM
PAUL_2's Avatar
PAUL_2
Transmission Code
I believe K is the C6
Old Sep 5, 2001 | 06:49 AM
getu12's Avatar
getu12
Transmission Code
Paul, Thank you.
Old Dec 31, 2001 | 09:39 PM
m79f100's Avatar
m79f100
Post Transmission Code
m79f100 hi,paul could you tell what tranny i might have,87,302,F150 xlt,shortbed.thanks,mark.
Old Jan 1, 2002 | 12:53 AM
PAUL_2's Avatar
PAUL_2
Transmission Code
If you look on the sticker on the inside of the drivers door it will have a section that says Trans , give us the code & Im sure one of us will be able to help you out . Do you have an auto or manual trans , that really helps narrow things down ?
Old Mar 11, 2002 | 08:41 PM
johnstephens's Avatar
johnstephens
>down ?
I too would like to know the specific type of transmission that is installed in my 1996 F-150XLT with 302v-8 , auto transmission and 2wd.
The door code for the transmission is u.
I am having a slight problem with the transmission. It seems as though the transmission is shifting into the next higher range at too low of a speed, and therefore tends to "bog down" as it cruises. I am able to temporarily take care of the problem by disabling the overdrive--therefore not allowing it to shift into OD unless I re-enable it when I get on the highway.
I checked the fluid level and added about 1/2 pint to get it into the normal range. The truck has only 29000 miles (I just bought it from an older couple that used it only occasionally). Unfortunately, I think that they failed to have routine maintenance performed as well.
Thanks in advance for the help!
John
Old Mar 12, 2002 | 03:49 PM
michaelskerrett's Avatar
michaelskerrett
Just about any transmission shop can adjust the shift ranges for you. Shouldn't take more than about 15 minutes (of course for a nominal fee) and they will test drive your truck with you after the adjustment to be sure they shift where you want.
Old Mar 12, 2002 | 03:54 PM
michaelskerrett
