1978 - 1996 Big Bronco
steering problems
Old May 22, 2015 | 04:54 PM
lickskilletkid's Avatar
lickskilletkid
steering problems
i just replaced ps pump and rebuilt gear box on 87 bronco. with engine running i can turn left fine but turning right i hit a hard spot halfway thru the cycle then it eases up towords right lock then turns back left easy. the pump will whine at full left lock but not full right lock. with engine off i hit hard spot in the middle going both directions. it will blow fluid out of resevior going left but not going right when i hit the hard spot. this is all with no pitman arm attached. did i mess up the gear box rebuild or is there an air bubble or something in there?
Old May 22, 2015 | 04:56 PM
lickskilletkid
with tires and tie rods attached it will turn left fine but is impossible to turn right
BeastF-250
1966 - 1977 Early Broncos
Jul 3, 2011 01:23 PM
rodneywar
Mar 8, 2010 02:25 PM
Alrobot
May 27, 2009 09:48 PM
tonygray
Jul 31, 2006 09:19 PM
Davinster
Dec 13, 2004 06:36 PM
