Reverse lights not working
Old Jun 1, 2015 | 08:57 AM
F250_'s Avatar
F250_
I had a similar issue on mine about 6 months after installing brighter LED bulbs in the rear. At the same time, I discovered my dash lights flicking in and out every time I shifted gear with the gear shift lever on the column. Have not torn into it yet, but I'm suspecting a worn wire (or several) in my steering column.
Old Jun 27, 2015 | 12:44 PM
str$ke-it's Avatar
str$ke-it
Don't mean to thread jack but its related. Does the gas engines use the same auto trans as the 7.3's? I believe the reverse switch on my truck (7.3 auto) is bad as I have no reverse lights as well and my brother has a gas excursion parts truck that if the same I could swap them out to see if thats the culprit.
Old Jun 28, 2015 | 09:18 AM
timmyboy76's Avatar
timmyboy76
Remove both,l and take a gander....mine was just that, corroded at the terminals, BUT still usable, with new leads soldered on
Trath67
Mar 19, 2021 08:20 PM
Ricky Melton
Escape & Escape Hybrid
Mar 11, 2019 08:16 AM
beefey
Nov 25, 2017 05:06 AM
ssande
Jun 22, 2017 10:20 AM
AMEC Electric LLC
6.7L Power Stroke Diesel
May 16, 2011 09:28 PM
