Def Question, miles to empty
Old May 22, 2015 | 06:28 AM
lpshiner's Avatar
lpshiner
Originally Posted by senix
When I am traveling out of the area I take a couple of jugs with me.
I don't carry them at home because of the storage temps. They would get too hot in the truck.
You should be getting plenty of warning though before running out. I suspect because of not being full in the first place it was a big confused.
I use the ford fill spout. It will work on most any of the refill jugs. I just rinse it and put it in a Ziploc for reuse.
This was not a first fill issue, I have filled the def tank 5 times since I have owed the truck. I buy def from Love's at the pump.
I just raised the question because I too thought you had plenty of warning before going empty and in this case I did as I was close to home where def availability is plentiful. However, it may not be the case while on the road traveling in the middle of nowhere.
Old May 22, 2015 | 06:36 AM
senix's Avatar
senix
Yeah, So I carry 5 gals with me when on the road for that very reason.
I can get about 4900 miles off of the 5 gals so you know as you are getting closer but things change so I carry it with me.
cbhughan
6.7L Power Stroke Diesel
Oct 6, 2017 05:28 AM
4bigred
May 8, 2015 07:48 PM
breeno
Dec 30, 2013 10:09 PM
d90000
Dec 24, 2010 12:29 PM
cHiLi 11
6.4L Power Stroke Diesel
Jul 26, 2007 01:48 PM
