I'm stumped
Old May 18, 2015 | 03:21 PM
High76boy's Avatar
High76boy
I'm stumped
Here's the verdict I just did a egr delete and oil cooler in my 6.0 ex I got everything done fired the truck up and it ran like crap threw some INjector codes so I started unplugging injectors to see which one were not firing and when I unplugged cylinder 4 the truck started running better and is firing on all cylinders except 4 when I plug 4 back in it runs on Half the cylinder and like crap again? Ever heard of that what's the fix? Any info helps
Old May 18, 2015 | 03:24 PM
dannyboy950's Avatar
dannyboy950
Useually a bad injector or wireing issue to the injector.
Old May 18, 2015 | 03:41 PM
Rusty Axlerod's Avatar
Rusty Axlerod
disconnect the suspect fuel injector connector and test the injector pins for resistance. measure the resistance between the suspected fuel injector pins,component side.
pins 1 and 2 =0.2 to 3.0 ohms
pins 3 and 4= 0.2 to 3.0 ohms
pins 1 and 3=greater than 10,000 ohms
pins 1 and 4=greater than 10,000 ohms
pins 2 and 3=greater than 10,000 ohms
pins 2 and 4=greater than 10,000 ohms
if the resistances are not within specs the fuel injector solenoid is bad and the injector will need replaced.
if the resistances are good you need to check the ficm.
A standard "noid" light from the parts store will work on harness side.
Old May 18, 2015 | 03:42 PM
High76boy's Avatar
High76boy
How do I check the wiring? Truck ran great prior to the egr delete and cooler swap
Old May 18, 2015 | 03:44 PM
High76boy's Avatar
High76boy
Beat me too it lol ficm is good it new I will check the wiring in a few
Old May 18, 2015 | 03:46 PM
High76boy's Avatar
High76boy
With it running good before the swap I don't see it being a bad injector
Restlesswildman
Jun 19, 2015 09:03 PM
rusbukt
Sep 22, 2014 07:56 PM
spanky350
Dec 29, 2011 06:16 PM
florida_1959
Nov 16, 2010 08:16 PM
Ratkat
Aug 29, 2008 05:36 AM
