07 A/C issues
Old May 18, 2015 | 12:27 PM
AzPete's Avatar
AzPete
07 A/C issues
07 Sport Trac, Limited, 4x4, V8, dual climate control, 115,547 miles. Runs great, a/c indicates full charge, cools great at low rpms. Higher rpms and the a/c tends to fluctuate between cold and cool.....not hot, but close to warm. Let it idle again and it will freeze you out. Temp settings do make a difference but still tends to run warm and cold at higher rpms. Same thing when in the manual settings. Has nothing to do with the a/c cutout on hard acceleration as the compressor is staying on during the problem time period.
No noises that would indicate vacuum issues. All air diversion selections work as they should.
I am wondering how the a/c monitors the temp settings to mix the air for warmer settings.
Feels like it has low freon but the gauges indicate full so I am lost.
slcdzl
Jul 11, 2011 08:03 AM
countryboy73703
Jun 24, 2011 04:31 PM
jackiedc7
Jul 12, 2004 06:47 PM
dgalloway
Aug 26, 2003 08:36 AM
jetnjmy
1997 - 2003 F150
Aug 19, 2003 10:27 PM
