Help!
Old 05-18-2015, 09:22 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Originally Posted by Thor'sHammer
I actually think the STC blew. It was so abrupt with very little warning. The slightly rough idle with wavering ICP then total release of pressure just sounds like a failing fitting to me.
Well I guess you will see when you pull the HPOP to replace the STC, if it did blow apart it will be obvious but the fact that the IPR had a pushed in screen tells a story as well.
Old 05-18-2015, 09:28 PM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
Are you saying you think the IPR could be the culprit or HPOP?
Old 05-18-2015, 10:28 PM
mustang_309
My feeling has been it is the IPR valve but you really should replace the STC regardless if it has failed or not and when you remove the HPOP to replace the STC fitting you will know if it failed as it will just pull apart. As far as the IPR goes some times you can remove the screen and push the plunger down with something ( just be careful not to score the bore or plunger ) and flush it really good with carb cleaner and install new orings and screen and reinstall it, you may get lucky and it will still work.
Old 05-18-2015, 10:55 PM
Thor'sHammer
I am going to replace both the STC. IPR and ICP due to the advice given here. Thanks everyone. I've ordered all of the necessary parts to do this and look forward to hearing it run again.
Old 05-19-2015, 01:08 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Your posting symptoms of how an IPR plugs suddenly after oil cooler replacement
Plus there was physical damage to IPR
They don't usually run with a blown STC FITTING
Old 05-19-2015, 01:49 PM
Thor'sHammer
It doesn't run. It won't build ICP pressure at all. It also happened suddenly in traffic which made me believe something ruptured.
Old 05-19-2015, 04:41 PM
Thor'sHammer
STC looked good, even though I am replacing it. I ordered the ICP test fitting yesterday so if the new IPR and fitting kit don't take care of the leak, I'll have that to troubleshoot further when it gets here. I do have faith that the problem lies in the IPR, good thing a new one will be here tomorrow.
Old 05-19-2015, 06:14 PM
mustang_309
It is a good thing you are updating the STC and now that is one thing you wont have to worry about and the fact that your old IPR had the screen pushed in and had a hole in it points squarely at the IPR being your problem.
Old 05-20-2015, 08:41 PM
Thor'sHammer
It's alive!!!!
Installed the STC kit, new IPR and reassembled the engine in about 2 hours, and then with fingers crossed I cranked it. She sprung to life about 30 seconds later and runs better than ever.....and then the alternator died.
You guys rock.
If any of you are ever in the "Northern Neck" area of Virginia, visit VFW post 10574 in Colonial Beach. I'm the post commander there and will buy many beers for all of the good advice given here.
Thank you again.
Old 05-20-2015, 09:50 PM
mustang_309
It's alive!!!!
You guys rock.
Thank you again.
glad to see that you got her going and thank you for the update.
Old 05-21-2015, 06:47 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Yes those IPR plug and blowout fast
You saved a future breakdown with the STC and it can be nasty when they blow
Glad you rolling again thx for update
odeent
06-30-2019 06:25 PM
Jxltrucking
03-15-2017 01:56 PM
konadog
1999 to 2016 Super Duty
02-08-2015 01:40 PM
Fungus232
08-09-2010 12:50 AM
Texascadillac42
01-10-2009 12:58 PM
Quick Reply: Help!
