This weeks problems...Thermostat, echaust and shaking.
Old May 17, 2015 | 05:11 PM
jerryparks's Avatar
jerryparks
Few fairly big issues to sort out this week.
First off, replacing my thermostat and thermostat housing, which I understand to be 3 bolts and swap them out.
Secondly, my exhaust is falling apart. I broke a hanger in the rear, and now my exhaust is broken off at the cat, but it looks like it just slides back in? any advice would be great!
Third, when I'm in 5th doing between 40 and 55 my truck vibrates like hell. It's never done this before.
Any help is much appreciated.
Old May 17, 2015 | 07:47 PM
Holmesuser01's Avatar
Holmesuser01
A thermostat and housing is a straight-forward job. Use a 195 degree thermostat. Don't overtighten the bolts.
The exhaust system is welded together. I have a local shop here that does nothing but exhaust work, and does custom work. He's very good.
Vibration? Tires? balance? Front end alignment? Lots of If's here.
Old May 17, 2015 | 08:05 PM
jerryparks's Avatar
jerryparks
Is there anyway I can bolt my exhaust together?
Old May 17, 2015 | 08:44 PM
Holmesuser01
They make clamps for exhaust pipes... Your pipe sections need to be made to slip onto the other sections of pipe so you have something for the pipe clamps to compress. If you're trying to put the old pipe back on after it broke off the converter, then no, it won't work.
Harrier
27
Aug 5, 2022 06:55 AM
4.9inline6
Exhaust Systems
Feb 23, 2006 04:21 PM
TrickStyle3L
Aerostar
15
Feb 15, 2006 08:53 PM
FordPowerStroke
Mar 5, 2005 01:47 AM
sr512
Modular V10 (6.8l)
Feb 18, 2004 09:10 PM
