Another member bit by the "related threads" beneath the real thread while searching for the reply box. He just scrolled down a bit too far. Probably meant to add a post to this thread...https://www.ford-trucks.com/forums/1...ggestions.html
Easily the most stupid and annoying thing I can't stand about the updated version of this forum.
You made me look. You can disable related threads.
Click on your name in the upper right corner.
Click on Edit Options
Scroll down to the Thread Display Options
The last one in that block is Related Threads. Change it to Disable Related Threads.
Scroll all the way to the bottom and click on Save Changes.
Thanks for making me look. The related threads was always annoying. More often than not they weren't related.
And if you scroll too fast you find yourself lost.
Thanks Joe. I didn't think it was a new problem but it's always been annoying. Funnily enough this was a closer related thread than usual. At least it's from the same sub-group!
Is this the area you're talking about.?
If so I still see related threads at the bottom of this and all the other threads..
Yes, if you have "Related Threads" disabled, you see a list. If it is enabled, however, you can scroll right past the list and into the actual related thread.
That doesn't happen if you have the newest post first, as the new post is on top and the oldest post is down by the related thread list.
