First Time Start Today
Old May 16, 2015 | 04:27 PM
jrockdiddy's Avatar
jrockdiddy
Well, it turns out to be bad news. Not too terribly bad, but more work and time. Got everything wired, fluids all in, started priming the oil pump, once the block was full of oil, oil started pouring out the back of the block right next to the rear main seal. Suspect? Oil galley plugs.... So, gotta drop the transmission and pull off the flywheel and see where its coming from.. To be Continued....
Old May 16, 2015 | 04:43 PM
drptop70ss's Avatar
drptop70ss
better to find it now than after starting the engine!
Old May 16, 2015 | 04:55 PM
jrockdiddy's Avatar
jrockdiddy
true, I could look at the bright side. But, I was so excited about hearing that thing run today after 2 1/2 years
Old May 16, 2015 | 09:14 PM
ben73058's Avatar
ben73058
Hey Jason,
I think it's exciting you got it fired up!!! So it leaked a little oil -
Do you have any video of it running?
When we finally got our's ready for it's first run - it went about 1/2 a mile & all 4 brakes locked up solid in an intersection .... nice.... Takes a few months to shake out all the things that need attention.
Hang in there.
Ben in Austin
1950 F1
Old May 17, 2015 | 09:30 AM
jrockdiddy's Avatar
jrockdiddy
Didn't try to start it. When I primed the oil pump, oil was pouring out of the back of the block where the bellhousing meets.
Old May 17, 2015 | 09:57 AM
52 Merc's Avatar
52 Merc
As noted above, better to find out this way than when it's running itself out of oil, quickly. Count yourself fortunate, even if it won't be a fun fix.
Old May 17, 2015 | 11:07 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Could be a lot worse. Tomorrow is another day. To put it in perspective, what's a couple more days after 2 1/2 years? But I do understand your disappointment.
Old May 18, 2015 | 11:20 PM
jrockdiddy's Avatar
jrockdiddy
Found my culprit for the oil pouring out of the rear of the block. I'll let you guys figure it out.
Also think my timing chain cover is weeping. Might be the wrong timing cover also. It's a stock timing cover, 351w, but I have the march pulley system that calls for reverse rotation water pump 86-93 mustang. I think I'll worry about getting the transmission back on and then tackle the front issues
There's a threaded bolt hole near this puddle that doesn't have a bolt. You can't put a bolt through the water pump to plug it, because there's no bolt hole. So my thinking is that I need a different timing chain cover.
dizzyfingers03
Mar 31, 2013 08:14 AM
Ehkart
132
Feb 19, 2010 06:59 PM
yendor
General Automotive Discussion
Dec 2, 2008 07:36 PM
jpjahn
13
Dec 29, 2006 03:38 PM
Jebadiah04
Feb 7, 2005 10:10 PM
