Just got my Lariat trim truck and learning all the settings available. Does the truck have DRLs? Mine does not, US specs. I found a setting for Daytime lights but it doesn't seem to make any difference if it is set to On or Off.
I thought DRL were mandatory these days. I'm pretty sure they are in California. Maybe it's a state-by-state thing, but it doesn't make sense that if some states require them, that they would only enable them in those states?
I just checked the Ford web site, and DRL are included in all the base packages. So even on the XL with the base-base package (100A), it includes DRL. From the web site:
The 100A Equipment Group includes these standard features:
Exterior Features
• 170 Degree Rear Door (SuperCab)
• Black Front Bumper Fascia
• Cargo Lamp integrated with Center High-mounted Stop Lamp
• Easy Fuel® Capless Fuel-Filler
• Single Rear Exhaust
• Black Three Bar Style Grille with Black Nostrils and Black Surround
• Halogen Headlamps
• Black Tailgate and Door Handles
• Mirrors, Sideview – Manual-folding, Dual Manual Glass with Black Skull Caps
• Spare Tire/Wheel Lock
• Stone Cuffs, Front & Rear
• 17-inch Silver Steel Wheels • Daytime Running Lamps
Interior Features
• 1st Row Manual Windows
• 2nd Row Fixed Windows (SuperCab)
• 2nd Row Manual Windows (SuperCrew®)
• 2.3-inch Productivity Screen in Instrument Cluster
• 4.2-inch Center-stack Screen w/Audio Controls
• Air Conditioning
• AM/Stereo (4 speakers with Regular Cab, 6 speakers with SuperCab and SuperCrew®)
• Black Vinyl Floor Covering
• Dome Light
• 12V Front Powerpoint
• Rear Window with Fixed Glass and Solar Tint
• Day/Night Rearview Mirror
• Manual Tilt/Telescoping Steering Wheel
• Driver Side Visor / Passenger side Visor with Mirror
Power and Handling
• 3.5L V6 Ti-VCT with Flex-Fuel Capability (Standard on 4X2/4X4, Not Available with 157” or 163” Wheelbase)
• 2.7L V6 EcoBoost® with Start/Stop System (Standard on 4X2 with 157" or 163” Wheelbase)
• 5.0L V8 with Flex-Fuel Capability (Standard on 4X4 157" or 163” Wheelbase)
• 4X4 Electronic Shift-On-the-Fly with neutral Towing Capability
• AdvanceTrac® with Roll Stability Control™
• Independent Front Suspension
• 4-Wheel Disc Brakes with ABS
• Curve Control
• Electronic Six-Speed Automatic Transmission with Tow/Haul Mode
• Hill Start Assist
• Fail Safe Cooling
Safety/Security
• Driver and Passenger Front Airbags
• Driver and Passenger Seat-Mounted Side Airbags
• Safety Canopy® Side-Curtain Airbags (1st and 2nd row coverage)
• Tire Pressure Monitoring System
• Manual Locks
Ford Order guide shows it as available on XL and standard on XLT and higher. It comes with the power equipment group which is standard on 101a. So ALMOST all of the trucks will have it.
That's what I thought. Mine does not have working DRLs. I've tried both settings, enabled and disabled, and not working. I guess I need to call the dealer tomorrow.
Do you have somebody checking for you or are you checking yourself? Like others have stated the DRL's are off until truck is put in gear.
The above list is the 100a list, which is the base. I think they all have them these days.
