Sponsored by: Auxito
P0455 & stalling
Old May 14, 2015 | 07:02 PM
ggenovez's Avatar
ggenovez
P0455 & stalling
Hi all,
New guy here.
My truck has been stalling on stops for the past few days. Runs fine when I first fire her up and on the highway, but sometimes when I come to a stop she stall.
Today, all of a sudden I get a code P0455. Most places say to replace the fuel cap but nobody is complaining about stalling. I'm thinking my problem is worst than the average bear, and the fact that the cap was replaced a couple of years ago.
So can it be the evap purge valve? how do I test it?
Thanks!
G
Old May 14, 2015 | 07:29 PM
Bluegrass 7's Avatar
Bluegrass 7
Have you looked up the code?
What does the description say?
Your stalling is not the 455 code.
The intake air controller is not recovering idle. Is it sticking etc?
Some diagnostics and checking are in order to see what happening.
Good luck.
Old May 14, 2015 | 08:41 PM
ggenovez's Avatar
ggenovez
Thanks bluegrass
P0455Evaporative Emission Control System Leak Detected Gross Leak
Is the only code thats in there.
Ill pull the iac and clean it but i noticed ever since the code came up it stopped stalling. Ill double check that tomorrow
Old May 17, 2015 | 09:05 AM
ggenovez's Avatar
ggenovez
Pulled and cleaned the iac and it still has trouble. It stalled this morning and was hunting for idle after i cleaned it yesterday
Old May 20, 2015 | 08:56 PM
Bluegrass 7
The IAC may have a fault you cannot clear by cleaning.
It has a spring loaded diaphragm that acts like a dash pot.
In order to do this function the diaphragm has a very small bleed hole to control air flow in and out behind the diaphragm.
If the hole is blocked it will not function as a dash pot and you cannot get at it to tell.
This often shows up at cold start as a normal start then stall because the IAC cannot react to the computer signal to control it and airflow for hot idle and cold high idle..
A way to tell at normal hot idle is remove the plug.
If it stalls or lowers the motor idle the IAC is working at that moment.
Good luck.
Old May 21, 2015 | 09:38 AM
ggenovez's Avatar
ggenovez
Thanks Bluegrass.
Ace!
Jun 26, 2017 05:19 AM
pleshdog21
1997 - 2003 F150
Sep 10, 2013 06:42 AM
uno
Feb 22, 2009 09:01 PM
madcatter33
Apr 14, 2008 08:17 PM
bamaguy
Jan 31, 2004 09:59 PM
