Factory Trailer Wiring
Old Apr 2, 2015 | 04:13 PM
Diesel_Brad's Avatar
Diesel_Brad
Ok, I am probably going to regret this, BUT.........
I Am wiring up my "new" trucks trailer wiring harness and need a little help. I cannot find my schematic.
This is for trucks with the FACTORY TRAILER WIRING. NOT Joe Blow's hack job.
This has 2 plugs under the rear bumper. One has 3 wires(Bk/Gr, Bl,Or), One has 4 wires(Wh,Yl,Gr,Br/Wh)
So far I have figured out...
White = Ground
Yellow = Left
Green = Right
Orange = 12V(Batter charge)
Brown/White= Running
Blue = Trailer Brakes
Black/Green = Backup lights
Anybody have a schematic?
I THINK....
Orange is 12+
Blue is Trailer Brakes
Black/Green is Backup light
Old Apr 2, 2015 | 04:41 PM
White 97 xlt's Avatar
White 97 xlt
Thanks to Subford for this one.....
Old Apr 2, 2015 | 04:47 PM
ifrythings's Avatar
ifrythings
10 characters
Old Apr 2, 2015 | 05:02 PM
Diesel_Brad
Thank you gentlemen. I went ahead and edited my original post to show the correct colors
Old Apr 2, 2015 | 05:20 PM
Diesel_Brad
Well now I feel Dumb
the factory relays and harness is missing from under the hood
Old Apr 2, 2015 | 05:45 PM
White 97 xlt
That sucks for sure!!!!!
Old Apr 2, 2015 | 05:46 PM
Diesel_Brad
Am I correct in thinking I can just get that relay box and piece of harness, then plug it into my existing fuse panel under the hood?
Old Apr 2, 2015 | 06:15 PM
ifrythings's Avatar
ifrythings
Your truck is diesel isn't it? On the diesels the relays are in the under hood fuse box
Old Apr 2, 2015 | 06:18 PM
subford's Avatar
subford
If C149 & C105 are there under the hood and the truck is wired from the factory for the trailer down the drivers frame rail you can.
note that fuel tank plugs may differ for a Diesel.
Old Apr 2, 2015 | 06:19 PM
Diesel_Brad
Actually there is an Aux box that attaches to the under hood box for the trailer pkg. It consists of 12v power and backup light relays.
I robbed it off one of my other trucks, I will have to replace it later
Old Apr 3, 2015 | 08:07 AM
Diesel_Brad
Old Apr 3, 2015 | 08:42 AM
subford's Avatar
subford
Those two plugs are C149 and C105.
Old Aug 31, 2015 | 04:56 PM
Diesel_Brad
Ok guys, back to chasing a Non functioning trailer brakes.
fuse 21 under hood(30 amP) is good.
But I am not getting any power to the plug at the rear of the truck(brake pedal depressed and brake controller showing voltage)
Suggestions? What color at the rear bumper for the stock harness should I have power on?
Old Aug 31, 2015 | 05:11 PM
subford's Avatar
subford
A Dark Blue wire.
Old Aug 31, 2015 | 05:26 PM
Diesel_Brad
Ok, figured out my problem. My $300 brake controller has taken a crap
Looks like I will be buying one of those P3 controllers
Adam Meier
Jan 20, 2019 10:36 AM
Cummings Guy
43
Oct 28, 2017 01:47 AM
Tugly
24
Oct 2, 2017 04:28 PM
jwhopson
Nov 18, 2012 12:19 PM
paxx
Electrical Systems/Wiring
Jan 29, 2009 06:47 AM
