towing a truck home safely
on
I was going to stuff a couple rags in the ends of the axles to keep the oil in. I'm not sure it will fit, but I've had another Chevy on a similar tow dolly with room so it should.
I'd just drive it home if the front end wasn't so bad
The thing that scares me about flat towing (or dolly-towing) without dropping the driveshaft or pulling the axles is the t.case. I know that a lot of them are supposed to be fine with it, but I met a guy when I was fourwheeling once in Colorado. He had flat towed his J**p there from Texas and at some point in the tow his t.case seized up. He ended up renting a J**p that week. Dropping the driveshaft is easy enough that it's not worth the risk (and I'd choose to drop the driveshaft before pulling axles too, but that's just me).
I don't think AAA will tow a vehicle with no plates and an outdated registration! They don't even like towing you if you aren't on the side of the road! My cousin's car just quit completely (needed more than a jump) at my other aunt's house. We had to PUSH THE CAR INTO THE ROAD before they would tow it. They didn't want to take it out of the driveway
