Interior Help
Old May 13, 2015 | 09:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Gary Lewis
That would be cool to do to one of our trucks! That plus a starter button on the floor under the clutch pedal would freak everyone out.
It wouldn't freak out Studebaker owners, cuz that was the only way to start these cars from the mid 1930's thru the early 1950's.
Some year Nashes also had this feature, but on some, you had to push the column shift lever forward to start these cars.
1940's, some 1950's Buick and Packard had the starter switch located below the gas pedal.
Charles Kettering, the founder of DELCO, invented the first self-starter. First vehicle in the world to have it: 1912 Cadillac.
Had a huge spring loaded button on the floor that you had to 'mash on' with your foot. Within a few years, Kettering became GM's chief engineer.
Old May 13, 2015 | 09:36 PM
Tedster9's Avatar
Tedster9
My Dad talked about Kettering visiting the diesel boat he served on. Seems right after the II world war we tried fitting the (German) snorkel system on American subs, though had lots of issues. He was there to help with some of the engineering problems. The conversion to nukes eventually made all that pointless but in 1946 it wasn't.
Old May 13, 2015 | 10:11 PM
Gary Lewis's Avatar
Gary Lewis
Yep, I was aware of the Nashes having that feature, which is why I said it. But not about the Buicks - apparently that was gone by '55 as ours didn't have it. Nor did the '57.
Old May 14, 2015 | 10:49 AM
SSellers's Avatar
SSellers
My '49 Chieftain is the first year Pontiac without the foot start. I think for several GM cars 1949 was the first year that their models weren't really just '41s and '42s after WWII. Oh yeah, and it's got some weird button on the floorboard......along with a hole in the carpet where you check the tranny fluid.
Old May 14, 2015 | 11:06 AM
ctubutis's Avatar
ctubutis
Nobody has complained about removing the hand crank below the radiator... or the flip-up steering wheel ("fat man" steering wheel)... or moving the gas tank from below the front seat, or the battery from below the rear seat floorboards (made of wood - actual boards).
Old May 14, 2015 | 11:23 AM
SSellers's Avatar
SSellers
Speaking of that, my heater core is under the front seat and works way too good but there's zero adjustment from inside the car.
Old May 14, 2015 | 11:42 AM
NumberDummy
1946/48 Chevrolet, Pontiac, Oldsmobile (except 1948 98), Buick; 1946/47 Cadillac, 1946/49 Cadillac 75 were "warmed over" 1942 models.
After the US became involved in WWII, production of 1942 models ended in either the first or second week of February.
Most automakers didn't resume production after the war ended until late 1945 or early 1946.
1948 Olds 98 and Cadillac (except 75) have the new GM bodies that were introduced in 1949. Cadillac 75 (limo/7 passenger sedan) got the new body in 1950.
Your "Tin Indian" Club Coupe has Hydra-Matic, 1949/50 Oldsmopiles with Hydra-Matic also have the hole in the hump to check the fluid. I owned a 1950 Olds Deluxe 88 Club Coupe for 17 years (1962/79).
One button on the floor: dimmer switch. 2 buttons on the floor, one adjacent to the other. Optional foot operated button to tune the radio.
Heater core under the seat. Packard thru 1956, Studebaker thru 1962 (Hawks thru 1964), probably others as well.
First Pontiac I owned was a 1929 Cabriolet (no heater available). 2nd Pontiac I owned was a 1953 Chieftain Deluxe 4 door, don't recall where the heater core was. Don't recall where it was on the '50 Olds either.
Old May 14, 2015 | 11:50 AM
emgee's Avatar
emgee
My 1988 Renault R8 had crank start capability (at the rear engine). Used it to great advantage during several cold winters.
Old May 14, 2015 | 01:38 PM
1986F150six's Avatar
1986F150six
Early VW Beetles could be started with a pull rope wrapped around the generator pulley.
Old May 14, 2015 | 01:48 PM
ctubutis's Avatar
ctubutis
Early VW Beetles also powered either the wipers themselves or the washer pump (I forget which) with air pressure contained in the spare tire (located beneath the bonnet).
They also had kerosene-powered heaters.
Old May 14, 2015 | 01:50 PM
1986F150six
It was the washer and the heaters were fueled with gasoline. EEEK!!!
Old May 14, 2015 | 05:15 PM
WilleyJoe.62's Avatar
WilleyJoe.62
As long as we're wandering down the path of misty yesteryears ...
I learned to drive in a '63 Dodge Dart. Push button gears on the dash. It seemed so 'normal' for a time. My mom had that car for 20 years, and there are still quite a few of them around. Plymouth Valiants also had this setup, I believe.
I have one exterior photo when we were kids - but here's one I just snagged showing that dash. Top to bottom is R-N-D-2-1. There was no "P", per se; you put the car in neutral and slid that parking lever down on the left:
Old May 14, 2015 | 07:10 PM
  #28
ctubutis's Avatar
ctubutis
And with an MPH gauge yes, I've seen it called that before that went up to 110!
Old May 14, 2015 | 07:18 PM
  #29
WilleyJoe.62
My sister had a 71 Gremlin. Hideous turquoise color, as shown. She couldn't make the payments, so my mom swapped the Dart with her. Six months later the Gremlin was dead and my dad towed it off to the JY.
Old May 14, 2015 | 09:04 PM
  #30
ctubutis's Avatar
ctubutis
The Gremlin... the baby brother of the Pacer... which looked like a pregnant Volkswagen Rabbit...
