I just picked up a 05' F450 Super-Duty it had the rear seat removed and the rear wall, under the window is bare metal. I have all kinds of road noise and dust coming in through the two vents on the back wall. Does anyone know how to fix this?
450 and 550 are work trucks, there's no comfort put into production, load F tires are screamers even straight line, If your not using it for work you can get load E 19.5's, that would stop alot of the roar.
Are the thin rubber flaps still in the vents on the back Of the cab? If not that why dust/dirt is coming in, if the rubber is missing either buy new vents from the dealer or get thin rubber and cut it to fit the vent and install them
I have had good luck with the rubberized bed liner for inside noise as a option other than dynomat. Do some searches on the vent noise for some options there. Foam or desperate times a towel stuffed in the vent has been done.
