Brake troubles
I took Them apart again today as I'm rotating the tires. Your right Jeff, the little cable is stretched. I've got new ones on the way. Should be here in a couple hours.
Green Sales
(800) 543-4959
xDennis Carpenter Ford
704-786-8139
It's easy to check operation with drums removed - yanking the cable should pull the adjuster level up, and releasing it should move the star wheel 1 click down, expanding the shoes.
Whatever these little silver cable cam things are called. The old ones weren't sitting in the holes like they are supposed to. Replaced them with new ones all is well. ( for now anyway...)
What are these things called? And can I get them separately?
search by part number
<form name="partSearchForm" id="part-search" action="https://www.partsvoice.com/partsearch" method="post"><fieldset><label class="clearfix" for="manufacturer"> Manufacturer </label>Ford<select name="makeCode" id="makeCode" style="min-width: 186px; opacity: 0;"><option value="">select manufacturer</option> <option value="AC">Acura</option> <option value="AF">Alfa Romeo</option> <option value="AM">Aston Martin</option> <option value="AU">Audi</option> <option value="BW">BMW</option> <option value="BE">Bentley</option> <option value="BS">British Sterling</option> <option value="CA">Case Corp</option> <option value="CT">Caterpillar</option> <option value="CH">Chrysler</option> <option value="DB">Cummins</option> <option value="DW">Daewoo</option> <option value="DA">Daihatsu</option> <option value="DC">Delco</option> <option value="FE">Ferrari</option> <option value="FI">Fiat</option> <option selected="selected" value="FO">Ford</option> <option value="FT">Ford Truck</option> <option value="FR">Freightliner</option> <option value="GM">General Motors</option> <option value="GE">Geo</option> <option value="HU">HUMMER</option> <option value="HT">Hino Diesel Truck</option> <option value="HO">Honda</option> <option value="HY">Hyundai</option> <option value="IF">Infiniti</option> <option value="IS">Isuzu</option> <option value="JG">Jaguar</option> <option value="JE">Jeep</option> <option value="KW">Kenworth</option> <option value="KI">Kia</option> <option value="KB">Kubota</option> <option value="LA">Lamborghini</option> <option value="LR">Land Rover</option> <option value="LX">Lexus</option> <option value="MN">MINI</option> <option value="MT">Mack Truck</option> <option value="MM">Magneti Marelli</option> <option value="MC">Maserati</option> <option value="MH">Maybach</option> <option value="MA">Mazda</option> <option value="ML">McLaren</option> <option value="MU">Mercedes Benz Truck</option> <option value="MB">Mercedes-Benz</option> <option value="MI">Mitsubishi</option> <option value="NF">Mitsubishi Fuso</option> <option value="MO">Mopar</option> <option value="MR">MotorCraft</option> <option value="NV">Navistar</option> <option value="IV">Navistar Truck</option> <option value="NI">Nissan</option> <option value="PC">Peterbilt</option> <option value="PE">Peugeot</option> <option value="PS">Porsche</option> <option value="RN">Renault</option> <option value="RR">Rolls Royce</option> <option value="SA">Saab</option> <option value="SN">Saturn</option> <option value="SC">Scion</option> <option value="SM">Smart</option> <option value="SP">Sprinter</option> <option value="ST">Sterling</option> <option value="SU">Subaru</option> <option value="SZ">Suzuki</option> <option value="TO">Toyota</option> <option value="TU">Tucker Rocky</option> <option value="VW">Volkswagen</option> <option value="VO">Volvo</option> <option value="WT">Volvo GM Heavy Truck</option> <option value="VT">Volvo Trucks</option> <option value="YG">Yugo</option> </select>
</fieldset><fieldset class="border-top last"><label for="zip">Zip/Postal Code</label><input name="zip" id="zip" type="text" maxlength="16" value="85204">
<button class="btn btn-large btn-primary" id="findPartsBtn">find parts</button>
</fieldset><input name="cmd" id="cmd" type="hidden" value="search"> <input name="pageNum" id="pageNum" type="hidden" value="1"> <input name="sortView" id="sortView" type="hidden" value="nOfNGroupingSort"> </form>
<!-- VisitVariant:null --> Sort by: Dealers with most parts<select name="sortViewSelect" class="sortby-select" id="sortViewSelectTop" style="min-width: 190px; opacity: 0;"><option selected="selected" value="nOfNGroupingSort">Dealers with most parts</option> <option value="favSort">Dealers that are favorites</option> <option value="distanceSort">Dealers that are closest</option> </select>
<!--/ sortby-wrap --> 1 - 6 of 6
<!--/ paginationinfo-wrap -->
<!--/ pagination-nav-content -->
<!--/ "pagination-nav-wrap pagination-nav-top" --> <!-- start iteration through inventory data--> <table class="table"><thead><tr><th colspan="2">suppliers with 2 out of 2 parts</th><th class="partnum"><dl><dd title="C1SS2A179A">1</dd> <dd title="C8TZ2A178A">2</dd> </dl></th></tr></thead><tbody><tr class="odd"><td class="contact-btn"><dl><dd class="contact-dealer-btn">Dealer Contact Info <dl><dt> Wesley Obsolete Parts Close</dt><dd>(606) 787-5293 </dd></dl>
</dd></dl></td><td class="dealer-info"><dl><dt> Wesley Obsolete Parts </dt><dd>LIBERTY, KY 42539</dd></dl></td><td class="parts"><dl><dd class="available ">2</dd> <dd class="available ">1</dd> </dl> </td></tr><tr class="odd"><td class="contact-dealer-btn"></td><td class="dealer-info"><dl class="dealer-info-toolbar"><dd class="email">Email dealer</dd> <!-- this line is diff --> <dd class="favorite">Favorite this dealer</dd> <dd class="distance">1531 miClose
</dd> </dl></td><td class="updated-date">Updated May 01, 2015</td></tr><tr><td class="contact-btn"><dl><dd class="contact-dealer-btn">Dealer Contact Info <dl><dt> Dennis Carpenter FordClose</dt><dd>704-786-8139 </dd></dl>
</dd></dl></td><td class="dealer-info"><dl><dt>Dennis Carpenter Ford </dt><dd>CONCORD, NC 28027</dd></dl></td><td class="parts"><dl><dd class="available ">5</dd> <dd class="available ">1</dd> </dl> </td></tr><tr><td class="contact-dealer-btn"></td><td class="dealer-info"><dl class="dealer-info-toolbar"><dd class="email">Email dealer</dd> <!-- this line is diff --> <dd class="favorite">Favorite this dealer</dd> <dd class="distance">1774 miClose
</dd> </dl></td><td class="updated-date"></td></tr></tbody></table>
