Engine under load/grades sounds like marbles...
New Parts since purchased.
New injectors
New PCV
New Coil on Packs
New Mass Air Flow Sensor
New Motorcraft Spark Plugs
New Fuel Filter
New Air Filter
New Coolant Temp sensor and Thermostat
New Oxygen Sensors
New Tires
Tranny Flushed and new filter
Oil Changed and new motorcraft filter
5 STAR tune 87/90 octane tunes... Went with tow/performance
Things shops have tested
Had cat measured using a heat temp gun and they said it seemed good.
Stock computer Flash to see if this fixed issue, it did not.
Fuel Pressure tested and verified good
Plugs look good.
All exhaust bolts are good.
No vacuum leaks, smoke tested multiple times.
Intake and valves cleaned using BG product and machine.
Compression checked on first two cylinders.
I run 90 octane in the truck ALL the time (chevron gas).. Truck gets about 11 mpg no matter if its a short in town driving or a long drive. I drive (26) miles one way to work highway cruising miles. I am also a very light footed driver.
I was told possibly the timing chain could have jumped a tooth and they would have to tear the engine down to figure that out. I didn't want to spend the $1000-$2000 for the shop to do this just on a hunch.
Oh, at idle I can feel a slight stutter every 5-10 seconds, RPM needle never moves, I have verified with a computer scanner as well. So I don't think IAC is bad. But that's the only other symptom that the truck exhibits that I would consider not normal. Truck has over 210k miles on the engine. Oh and just recently I have started to hear what I would call lifter tick, truck does need another oil change. Going to do that at lunch.
My brother has the same year vehicle but his is an excursion. He is running 265 tires vs my 285 tires but his vehicle seems like it has way more ***** and I imagine he is about 400-500lbs heavier with that huge gas tank... My pickup just seems low on power.
Any ideas?
Has this truck been "tuned" by chance?
I'd try a tank of 92-94 octane next time to see if the preignition-like noises settle down. If they do, then you know that pre-ignition is the issue and you can focus on the knock sensor and the timing of the engine.
My brother and I are both running the same axle ratio.
Tune was done by Mike @ 5star tuning, however.... the noise was there before his tune.
I was able to get some VP 110 from a friend and just put it in the tank... Drove a few miles and didn't seem to make a difference.
No one has been able to fix/determine the cause of the issue.
The only thing that makes sense to me is I have some type of un-metered air entering the system after the Mass Air Flow Sensor causing a lean condition, thus pinging... I have checked the elbow multiple times and can not find a crack in the system.
I never get a check engine light and when I scan I never get any codes being thrown. Basically the Electronics all pass according to the ECU.
It really doesn't matter what RPM range I am in, it will even ping at WOT sometimes. When I push the pedal slightly or below 1/2 way down I can ALWAYS get the truck to ping. Any slight grade it will ping. It's been driving me nuts.
Only time I was able to get rid of the pinging was with a different MAF that was ordered incorrectly for my truck. I threw a MAF code of course, but the truck ran great.
I am running 98 octane in the truck currently... Still pinging.
I am almost at the point to disconnect the MAF all together.
Have you had any MIL (check engine) lights with this condition? You may want to use your scanner and check the ignition timing under load. If over 43 degrees under acceleration, or timing is swinging around significantly, something is definitely up.
The fact the truck isn't running right and pinging violently, clearly indicates there is something really wrong. If it were me, I'd consider putting the stock settings back and start troubleshooting from there. If the SCT tune is already advancing timing more than stock, you're just making the problem worse.
Good Luck!
Kelly
Long Term Fuel Trim Bank 1 = .93
Long Term Fuel Trim Bank 2 = .95
Vehicle Speed 65mph, Spark Advance 28
Vehicle speed 68mph, Spark Advance 27
I can't stress enough I was running 98 octane fuel today....
Lowest I saw spark advance was around 12, highest was around 34.
Kelly: You can unplug the MAF and the truck will run just fine. Most OBDII compliant vehicles require multiple things to happen to go from open loop to closed loop... If they don't happen the truck just runs in open loop (doesn't look at 02 sensors) to adjust the air/fuel mapping. (Uses pre programmed data).
Vechicle operating temp up to 160 or above.
MAF needs to be reading correct specs
02's need to be heated and working
I know there is some other things that might need to happen... But the truck will run fine by unplugging a MAF. I used to unplug the MAF on my older camaro all the time and use open loop operation to see what the computer was doing as I would (datalog) the base stock tune so I could adjust my custom tune after I did a bunch mods to the car.
Anyhow, the ECU is reporting normal within spec variables from what I can tell.
Something like a clogged CAT, the computer has no way to check that as this model vehicle is not equipped with a post cat 02.
like I was stating before the ECU was showing everything running correctly and after running 98 octane and still making the same noise I was determined it couldn't be pinging like every shop or car buddy said it was. Audibly it literally sounds like pinging/detonation.
HOWEVER, I think I'm on the right path now. I was tired of the sound so I put on some decent gloves and just started grabbing around by the y pipe area and heard a tap tap. I kept feeling around and found these two bands loose. I imagine under certain hills or under load the truck vibrated enough to make these straps sound like detonation. I removed them, filled up with some 87 and drove 10 miles.... sound seems to be gone, will know more as I continue to drive it. It wasn't helping anything I can tell you that much. Can't believe I took it to a few shops and they couldn't find these things loosely rattling under there. Makes ya wonder what your paying for eh? If I didn't tear my shoulder and have back surgery I would have just dealt with it myself originally.
Here's to hoping these stupid metal clamps were the issue.
One day I heard a really bad rattle, and got to the point where I KNEW it was the muffler innards rattling. It wasn't. The support in front of the cat had come loose and it was only under load that it made a HUGE racket. Fun stuff...
I am going to remove the trans bell housing cover tomorrow and drive it around and see if the sound goes away.
Really hoping it's not an internal issue, but at this point no idea where else to look.
I have never heard the y pipe flutter people talk about so no idea if that's what I'm hearing, but it literally sounds too loud to be flutter. Sounds like pinging.
The wife is no mechanic and she asked today what is that awful rattling sound.
One is an exhaust sound. Maybe it is the dreaded flutter everyone talks about or maybe I just have a bad motor. Power seems fine now other than my transmission seems to shift late like its lazy.
When going up grades I can hear the knocking/pinging sound and I guess I am just gonna have to live with it. Turn up the radio and call it as good as its gonna get.
Without spending 20-30k on a newer truck I think its gonna be as good as it gets.
Otherwise I would be looking at a new transmission and converter along with a new engine. Which I imagine would run me somewhere around 11k?
It's just not worth the fuss. I am going to drive this bad chicken until its dead.
