Just purchased 4 days ago and transmission is dead
I just purchased a 2002 F150 Supercrew 4x4 4 days ago and have driven it less than 200 miles. I started it up and put in reverse and nothing. I checked the parking brake and it was off. I then revved the engine a bit and it lurched backward squealing the tires. I put it in drive and it stalled. I started it again and started moving forward and it made a grinding noise. The check engine light came on and the overdrive light is now flashing.
If the dealer won't help me, what could this be? It drove fine before this and showed no signs of trouble. I really can't afford a new transmission on top of just purchasing this truck.
Did you buy it from a new car dealer, a used car lot or a private party? If you bought it from a dealer did they give you any kind of a warranty? Can you still drive it?
Well, no help from them. Code scan shows P0751. I still have to research trouble shooting and repair options. How difficult is the shift solenoid to replace?
