Replacing Seats in a 91 supercab
Old May 10, 2015 | 01:05 PM
MCBrandon710's Avatar
MCBrandon710
Hi guy's I'm new to the forum, I just bought a 1991 F-150 super cab and it has the split bench in the front with the fold down arm rest. I'm hoping to switch it out for some nice bucket seats, are there any that are a direct bolt in? I tried to do some searching on here buy I mostly found info for single cabs. Thanks for the help.
Old May 10, 2015 | 08:13 PM
Diesel_Brad's Avatar
Diesel_Brad
Since a split bench with a fold down arm rest was not an option in 91, could you post a pic of what you have?
As for putting in buckets, YES, it is very simple since 50% of the supercabs trucks got them
Old May 11, 2015 | 10:02 AM
MCBrandon710
Ah you're right, I posted that before I went and picked it up, it's just the regular bench seat.
So would I just need to look for buckets from that year range? Do I need the brackets too? Thanks for the help.
Old May 11, 2015 | 10:54 AM
jas88's Avatar
jas88
Just be aware that if you use the factory captain's chairs, none of the holes will line up. Also you will need to brace the floor where you do eventually bolt the seats down. I did this conversion on my '91 and the floor cracked and split where I put the driver's seat. I am not huge, I weigh 210#, but it only took about 6 months for the floor to tear around the bolt holes. Trucks with factory captain's chairs have bracing underneath for this purpose.
If you want something that will bolt in, look for a 92-96 truck with the 40-20-40 seats. It has separate buckets and a center fold-down console and will bolt in place of your bench seat. This truck has the seat I am talking about: https://www.ford-trucks.com/forums/1...found-one.html
Old May 11, 2015 | 05:45 PM
Diesel_Brad
So only factory bucket seat equipped supercabs came with the bucket seat bracing?!?!
I assume you are talking a brick nose year?
And a 40/20/40 from a supercab bolts in just like factory buckets so you would be bracing the floor again. If you got a 40/20/40 from a reg cab or crewcab the seat does Not slide forward to access the rear of the cab, only supercab seats do that
Old May 11, 2015 | 06:00 PM
MCBrandon710
Thanks for the info guys. Sounds like it's going to be a bigger PITA than I originally thought. Silly me for thinking I'd find bolt ins
Old May 12, 2015 | 08:34 AM
jas88's Avatar
jas88
So only factory bucket seat equipped supercabs came with the bucket seat bracing?!?! I assume you are talking a brick nose year?
Yes, mine is a '91, no bucket seat bracing with the bench seat.
Oh, my bad, I thought they bolted into the bench seat holes. My son has this seat in his '95, I will examine it and measure to be sure. I am sure you are right about the access to the rear, his does not do that (it's a regular cab).
Old May 12, 2015 | 04:58 PM
Diesel_Brad
Regular cab and crewcab 40/20/40s bolt in with just 4 bolts like a bench seat. And are a "complete" assembly
A supercab 40/20/40 seat bolts in using 8 bolts just like buckets do. The inner 4 bolts also hold down the center seat They go in as 3 separate seats
Old May 13, 2015 | 08:23 PM
jas88's Avatar
jas88
Well, yeah, OK, that's the one I was talking about. I said "if you want something that will bolt in" but, to be fair, I did not think about the access to the rear thing.
There is a "rib" that runs along the underside of the floor to brace it. The bench seat holes are on that rib, so that provides the bracing. However, the captain's chairs bolts are outside of the rib, so that's why they need extra, add-on bracing.
bobs 80 f250
Mar 5, 2016 08:57 PM
Augy88066
Feb 15, 2015 11:24 AM
Splatts
26
Aug 19, 2012 09:10 AM
Jrock909
17
Mar 11, 2007 07:50 PM
ncmtnrebel
Jan 23, 2005 04:22 PM
