Starting problems
Old May 13, 2015 | 10:40 AM
frustratedF150's Avatar
frustratedF150
Starting problems
Battery charged cab lights and indicator lights on's turn the ignition key hear a click under the hood then no electronics. Any help would be appreciated.
1994 f150 4x longbox.
Txs again
Frustrated F150
Old May 13, 2015 | 03:58 PM
rla2005's Avatar
rla2005
Check the battery cables and connections as well as the ground on the engine block. Many times the connection looks good but need to be cleaned. Be aware corrosion can get underneath the insulation and create problems.
Old May 13, 2015 | 04:20 PM
daddylee100's Avatar
daddylee100
I just went through this on my truck. New starter relay (actually 2) new starter then replaced Positive cable and BOOM! faster starts and no problems since.. been 5-6 months now. All cables and connections looked fine but positive cable was corroded under insulation.
Old May 13, 2015 | 08:57 PM
frustratedF150
Tks, will try
MrCMO
Aug 18, 2018 07:08 PM
Red69
Jan 18, 2015 05:48 AM
jb50F1
Mar 30, 2012 10:31 AM
Ford Breakdown
Aug 26, 2007 08:34 AM
iamme9182
Sep 26, 2003 04:33 PM
