Lets talk about airbags.
Old May 10, 2015 | 09:43 AM
jerryparks's Avatar
jerryparks
I'm trying to replace my front bumper, as it has a couple of rust holes in it. Where are the bolts to remove it, and what do I need to do to keep my airbag functioning after I replace it?
Old May 10, 2015 | 02:51 PM
toby tough's Avatar
toby tough
I think there are a couple brackets that hold it to the frame. A couple nuts and bolts each. As far as the air bags I'm not sure. I think they are an inertia switch sort of thing. Looked in my books but don't have an answer for that one. Good luck.
Old May 10, 2015 | 03:17 PM
kaduh's Avatar
kaduh
The airbag sensors on my '96 are on the upper radiator support. There isn't anything on or near the bumper. Just an FYI.
Old May 10, 2015 | 10:30 PM
dixie460's Avatar
dixie460
Look behind the bumper and you'll see 4 nuts that hold it on.
Airbag sensors (the Primary Crash Sensors) are bolted to the radiator core support, so you won't be working with them, and just in case you wondering why they're the primary sensors, the Airbag Safing Sensor is the secondary one. Located inside the cab.
Old May 10, 2015 | 11:56 PM
jerryparks's Avatar
jerryparks
Ok, great. Where can I install tow hooks on my truck?
Old May 11, 2015 | 06:22 AM
dixie460's Avatar
dixie460
With a factory bumper the only place to install tow hooks is directly to the frame. You'll probably have to notch the lower edge of the bumper for them.
I like to use factory Ford tow hooks since they are closed loops instead of an actual hook.
redman84
Jun 18, 2010 08:01 PM
justin_brandstein
Apr 3, 2009 07:30 PM
RICE H8R
17
Nov 26, 2004 11:59 PM
Charlie's Truck
Paint & Bodywork
Apr 6, 2003 07:18 PM
Outpost22
Nov 23, 2002 09:14 AM
