Starting Rewire.
Old May 10, 2015 | 07:55 AM
Indybeer's Avatar
Indybeer
Starting Rewire.
I finally started rewiring my truck. I am using a kit from American Autowire that I got from Mid Fifty. First thing I had to do was paint the firewall. I only had the body shop paint it in primer. Luckily they gave me what paint they had left. I don't think it turned out too bad.
I have temp installed the dome light, and verified that it works using a battery pack. I also have run the wires for the lights and eng thru the firewall.
Next will be starting on everything under the dash.
There will be alot of unused wiring in the current configuration. But if I ever decide to upgrade the wiring will be there.
Old May 10, 2015 | 08:30 AM
96XL's Avatar
96XL
It looks like you are off to a great start. I am currently working in the same job. I chose to use the factory firewall pass-thru as well. I will be watching your thread I am curious to see the turn signal wiring. Do you have any photos of the fuse block install?
Keep up the great work!
Old May 10, 2015 | 10:42 AM
Rimrock F1's Avatar
Rimrock F1
Very familiar look. Takes some time and it all comes together. Good idea having extra circuits, never know what will come along.
Old May 10, 2015 | 05:14 PM
pbsdaddy's Avatar
pbsdaddy
I too will be watching with interest. My EZ wiring kit should arrive Monday and the 12 volt conversion should be here next Wednesday. I order the 12 circuit system as I know I will not be installing air or anything more than maybe a radio and electric wipers.
Old May 10, 2015 | 05:37 PM
Bluey Zedoff's Avatar
Bluey Zedoff
That harness looks like it already has terminals connected! Wow! Plug and play!
Old May 10, 2015 | 06:10 PM
harleymsn's Avatar
harleymsn
I agree! Mid 50 doesn't show that kit by name in the catalog, which harness is it?
Old May 10, 2015 | 08:28 PM
1951 f1 two's Avatar
1951 f1 two
Getting ready to wire my '51 F1, look forward to the tips and great info.
Old May 11, 2015 | 12:32 AM
mustangmike6996's Avatar
mustangmike6996
Even the kits with the unterminated (no terminals) ends isnt too bad (for any vehicle) because you can route the wiring any way that you please. The best part is being able to lay the harness out and figure out what goes where. Once you are done, install some loom or wire braid. Tape or heat shrink the ends to give a nice clean look.
http://images2.cableorganizer.com/f6...ages/03-f6.jpg
that is much better looking than the plastic. Then use fabric tape for the ends.
Old May 11, 2015 | 02:52 AM
Indybeer's Avatar
Indybeer
in the Mid Fifty 2014 1/2 catalog it the the custom harness with switches on page 46. item # 3264.
Old May 11, 2015 | 09:10 AM
Mixer man's Avatar
Mixer man
I'm almost to the wiring part myself. That's a sweet looking harness.
Old May 11, 2015 | 04:07 PM
tractormanbill's Avatar
tractormanbill
tractorman
I used EZ wiring and the tech help on the phone was the greatest.
Have enclosed picts of the fuse box mounting, I ran the rear wiring through the firewall and then back through the frame as I didn't like running wires under the carpet and then having to poke a hole out the back of the cab.
I started with split wiring harness but switched to self-sealing "Silicone" electrical tape from Delcity.net. After 24 hrs. it sets up solid. It works great, seals from water and takes lots of heat plus the results is smaller than using the split stuff. Regular electrical tape just will not take the heat in Texas. I had to remove some tape to add additional wires in some runs but that was no problems to slit with a blade and it peels of easily and then re-tape.
TractormanBill
One on the right is the silicone tape and the left are the split harnesses which I later replaced with Silicone tape.
Old May 11, 2015 | 05:15 PM
JimG1098's Avatar
JimG1098
TractormanBill
did you mount your fuse flock on the firewall under the hood? That is where I am thinking of putting mine. I also see you are using male/female conectors. What would they be for? Trouble shooting isolation?
Old May 11, 2015 | 05:17 PM
JimG1098's Avatar
JimG1098
What are you guys using to clip the wiring bundle to the frame going to the rear of the truck, My frame is pretty thick
Old May 11, 2015 | 05:19 PM
JimG1098's Avatar
JimG1098
Indybeer
I am going to use an EZ set up also.
Old May 11, 2015 | 05:29 PM
Indybeer's Avatar
Indybeer
Here is the mounted fuse box.
