Gear shift/ always in overdrive
Old May 9, 2015 | 06:19 PM
rossistheguy's Avatar
rossistheguy
hey I have a 1993 ford f250. Uh its stuck in overdirve all the time and the end of the gear shift which also has a button for it. You can also turn it. But a purple wire is broken off and so thats why its always staying in overdrive. I need to know how to fix it so it can be switched off overdrive and so I will also need to get the purple wire to be fixed to stay in and not come off. Please comment an answer and if you need me to explain better.
Old May 9, 2015 | 06:57 PM
wag53's Avatar
wag53
Is the purple wire broken or is the pin on the switch broken? The switch can be popped out by putting a small screwdriver in notch on the instrument panel side of the switch and pop it out, gently. The wires usually break at the base of the shift lever,iif so solder & heatshrink, make sure they won't get pinched again.
Old May 16, 2015 | 07:24 PM
rossistheguy
hey sorry I have responded. anyways ive talked to my dad some more. he says he thinks its just the purple wire. thats what it looks like to me as well.
Curbscape
Apr 26, 2016 02:18 PM
fightlivefree
Sep 17, 2015 07:59 PM
Dirtfarmer69
Nov 5, 2014 06:34 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
Dec 9, 2003 10:10 PM
Rtpjunior
Feb 15, 2003 06:25 PM
