Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Code 0403 - EGR Control Circuit
Old May 9, 2015 | 01:20 PM
scott91370's Avatar
scott91370
After about 6 months I finally got the alternator replaced in the Tribute. I totally forgot about the CEL that was on for EGR Circuit.
I've found a couple of pages ( OBD-II Trouble Code: P0403 Exhaust Gas Recirculation Circuit Malfunction ) that explain how to diagnose the issue but I was wondering if anybody here has dealt with the issue and if they suggest another route for something that may be more common than another thing.
Old May 10, 2015 | 07:17 PM
scott91370's Avatar
scott91370
Appears to be fixed.
The ground wire going into the solenoid was bad. I gave it a little tug since it never did ground out to activate the solenoid and it came right out. I was able to remove the pin from the plug and repair it.
Tomorrow will be the real test, I'm driving it to work for the first time in about 6 months.
Old Aug 12, 2016 | 10:30 AM
hagbard's Avatar
hagbard
EDIT: Whoops, replied to the wrong thread!
Ok, thanks.
I wonder can I just connect the solenoid ground to battery ground to energize it? That way I know everything after the solenoid is operating properly.
Can i check solenoid power plug ground to battery ground to check continuity to check the wiring?
hagbard
Aug 13, 2016 11:36 AM
msche398
Mar 24, 2014 06:54 AM
Spence Baker
1997 - 2003 F150
13
Mar 22, 2014 02:20 PM
ruwafl
13
Jan 12, 2010 04:49 AM
oldntrd
Jan 15, 2005 11:48 PM
