Runnig Hot
Old May 8, 2015 | 03:54 PM
oft's Avatar
oft
Runnig Hot
Hey all,
The 5.8 Winsor in my 76 is running hot. Hasn't overheated but will get past the L on the NORMAL on the gauge. This occurs when the truck is sitting still, temps will drop as I start moving and get some air flow. So, would a fan shroud help? Not sure what else to do, Radiator is good, stat opens.
If a shroud wont do it, I'm thinking electric fan.
Old May 8, 2015 | 05:31 PM
HIO Silver's Avatar
HIO Silver
Heck yeah a shroud will help. Right now all the mechanical fan is doing is circulating the dust in the engine compartment.
A mechanical fan should project no more than 1/2 of its pitch into the shroud. Allow an inch of clearance around the fan circumference to account for engine shift and vibration.
Add a bottle of Redline "Water Wetter" or Royal Purple's "Purple Ice" to reduce surface tension and promote heat transfer.
Btw, that stock gauge is as accurate as 00 buckshot. I suggest installing an aftermarket gauge.
Old May 8, 2015 | 07:07 PM
Jdeshler's Avatar
Jdeshler
^^ I agree a fan shroud will help tremendously
Its like having an AC in your car with non directional vents..
Old May 9, 2015 | 12:22 AM
oft's Avatar
oft
ok, gotta find one though. I'll try LMC.
1972RedNeck
Jul 25, 2012 07:58 PM
rwlacks
Jun 8, 2009 10:37 PM
78oldsmokey
Jul 27, 2005 12:36 PM
Dustin_86
Jul 14, 2004 06:41 PM
creeksider
Nov 11, 2000 06:19 PM
