Brake bushings
Old May 7, 2015 | 11:34 PM
spkatp's Avatar
spkatp
Brake bushings
Has anyone replaced brake and clutch pedal bushings. I just got replacement did a search and didn't see any post. What's the best way? Do you have to remove the entire assembly from the fire wall or will they come apart in place. 75 ford f100 4 speed on the floor. Any advise. Thanks.
Old May 8, 2015 | 03:57 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
This may be of help. See post #7
https://www.ford-trucks.com/forums/1...al-spring.html
Old May 9, 2015 | 10:57 PM
spkatp's Avatar
spkatp
I changed them out today what a PIA. The spring is really tight and didn't want to risk breaking the bushing on it so I decided to remove the entire brake assembly as a whole. Removed cockpit instrument to access top bolts, steering wheel base cover next to ignition switch, then out side removed master cylinder and power booster and mounting brackets. Back inside disconnect clutch rod brake arm. Its tight but possible slide toward the gas pedal. Took me 20 mins of head scratching to get it out and 3 to get it back in not sure how I lucked out. Figured this might help someone in the future.
Matt66
Aug 7, 2019 11:06 AM
65_f-300_I6
Sep 28, 2006 08:05 AM
BLACK NITE
Apr 26, 2006 08:36 PM
51dueller
Jun 1, 2003 11:14 AM
Polkat
Nov 29, 2002 07:28 PM
