Auto Locking Hub Question
Old 05-07-2015, 03:07 PM
wy4525's Avatar
wy4525
wy4525 is offline
Do any of you guys know the part#s for the auto locking hub gasket, o-ring, and torx bolts? Also the updated dust seal part# between the U-joint and the outer part of the axle tube that seals the shaft off from contaminates. I have searched and I just want to make sure I have the correct numbers, it seems there is more information on the 99-03 4x4 front ends than the 04-07's. Its the truck that's in my signature. Any help would be greatly appreciated. I was about to do ball joints, U-Joints, and all that good fun stuff and I wanted to replace the dust seals, and auto hub gasket and o-ring when I went in.
Old 05-07-2015, 03:10 PM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
Did you look online at tousely ford?
Old 05-07-2015, 03:16 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is online now
When I ordered my seals I called Tousley and they got everything I needed.
I didn't replace the lockout o-ring, fasteners or the paper gasket. There is no reason to unless it is damaged.
Old 05-07-2015, 03:24 PM
wy4525's Avatar
wy4525
wy4525 is offline
Yes, and the Locking Hub might just only require an o-ring, I have not disassembled anything yet to see, I am just preparing for it. Tousely's parts list don't include the hub lock o-ring, or at least I didn't see it if they did.
Old 05-07-2015, 03:26 PM
wy4525's Avatar
wy4525
wy4525 is offline
I may give them a call tomorrow if no one on here has the part numbers readily accessible.
Old 05-07-2015, 03:41 PM
dannyboy950
There was another guy on another forum was changeing his hub and bearings with part numbers but I can not seem to find his post now. Sorry so no help here.
Old 05-07-2015, 03:45 PM
wy4525's Avatar
wy4525
wy4525 is offline
Thanks anyway, I am having the same problem. I search and search with no results worth noting. Oh well, I'll call Tousley tomorrow, they are the ones I purchased my head gaskets, oil cooler, and all that from when I did my head studs. So I will call them if no one has the part numbers on here. Thanks again for helping!!
Old 05-07-2015, 03:58 PM
wy4525's Avatar
wy4525
wy4525 is offline
Okay, I found the part numbers for the Yellow O-ring on the Hub/wheel bearing, I have the part number for the axle shaft main seal, and the dust seal. So all I need is the one for the hub lock.
Old 05-08-2015, 01:30 AM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
This is my write up on the procedure not the best but has part numbers and helpful links
https://www.ford-trucks.com/forums/12...info-here.html
Old 05-08-2015, 05:27 PM
wy4525's Avatar
wy4525
wy4525 is offline
Thanks a lot lupuseven, that will work, it should be everything I need.
travisp_95
04-02-2013 02:17 PM
magnumak1
1999 to 2016 Super Duty
05-09-2012 10:01 PM
biketyke
10-13-2009 07:19 PM
Jager
09-26-2009 05:05 PM
Dre82s
01-30-2009 08:02 AM
Quick Reply: Auto Locking Hub Question
