Front hub O ring
Old Oct 13, 2009 | 06:16 PM
biketyke's Avatar
biketyke
Front hub O ring
I have a 2000 F250 with sotf 4 wheel drive, when i turned the hub from auto to lock at the wheel part of the o-ring came out between **** and hub. I pulled hub off truck took out parts untill i got to black rubber seal under the plastic parts . I am not seeing how to get to where i need to be . any help would be appreciated thanks. Sal
Old Oct 13, 2009 | 06:21 PM
SpringerPop's Avatar
SpringerPop
Not sure you can, at least at this time.
Read the short article in the gray block half-way down this page:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
You may have to set the hub lock to the "Auto" position and leave it there until Guzzle finds this O-ring.
Pop
Old Oct 13, 2009 | 06:47 PM
biketyke's Avatar
biketyke
Thanks SpringerPop I will look for a new hub . Guzzle really knows what he is doing great link !
Old Oct 13, 2009 | 07:19 PM
SpringerPop
You might want to consider sending the old one to Guzzle to experiment upon.
At one time he was looking for old ones, but I don't know if that's still the case.
Yes, Guzz has very-well documented the common maintenance items as he has done them over the years. Most of us use at least some of his pages as reference material when wrenching on the trucks.
Pop
sotwclarinetguy
May 20, 2012 05:54 PM
78 RedandWhite
Nov 5, 2010 09:55 AM
BII Plow Truck
Bronco II
Dec 22, 2009 07:32 PM
kameronth
1978 - 1996 Big Bronco
Aug 31, 2007 09:27 AM
