Warranty plate Decoding
Old May 7, 2015 | 02:34 AM
RustFreeBucket's Avatar
RustFreeBucket
Hi Everyone,
could any of you be so kind as to decode my warranty plate on my 65 F250? I also wonder, what could I find as a replacement for the 1V carb? I don't want to buy another intake manifold though.
VIN: F25BR673320
W.B.: 129
Color: L
Model: F250 (duh)
Body: 381
Trans: F
Axle: 24
Old May 7, 2015 | 05:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RustFreeBucket
Could any of you be so kind as to decode my warranty plate on my 65 F250?
VIN: F25BR673320 / WB: 129 / COLOR: L / MODEL: F250 / BODY: 381 / TRANS: F / AXLE: 24 / MAX GVW LBS: 07500 / CERT NET HP: 150 / RPM: 3600 / DSO: Omitted
You omitted some of the info, I was able to fill in most of it, except the DSO code, that when decoded, refers to a specific city and state.
F25 = F250 2WD
B = 300 1V I-6.
R = San Jose CA Assembly Plant.
673320 = 1965, assembled April 1965.
129" Wheelbase.
L = Holly Green.
F250 2WD, 7,500 lbs. GVWR / duh not! Besides the F250 2WD MODEL code, there's also an F251 2WD MODEL code: F250 2WD, 4,800 lbs. GVWR / F250 4WD's have different codes/GVWR's.
381: 3 = Medium Green Crush Vinyl & Medium Green Wicker Pattern Vinyl / 81 = 81A Standard Cab.
F = Borg Warner T-18 4 Speed Manual Transmission.
24 = Dana 60 Rear Axle / 4.10-1 / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
DSO: Omitted. This refers to what city & state the Ford District Sales Office was located in, where the original selling dealer ordered the truck from.
Since your truck was assembled in San Jose, the DSO code could be: 71 (Los Angeles/SoCal); 72 (San Jose/NorCal); 73 (SLC); 74 (Seattle); 75 (Phoenix).
74 = Seattle WA also includes vehicles sold in ID, OR & WY
Old May 7, 2015 | 05:34 PM
RustFreeBucket
Thanks for the information! it says 72 on it for the DSO, which makes sense considering I am from the SF bay area. I am just wondering, if the original t18 was swapped for a C6 automatic, do you think a T18 could swap back in without needing a new or different driveshaft to the dana 60? I am not sure if the length of the transmission would be that different between the two transmissions. I also know that my ford has the provisions for a clutch pedal assembly left under neath the dash though, so that should make things a little easier.
Old May 7, 2015 | 07:43 PM
NumberDummy
The driveshaft will be a different length C6 vs T-18. You will need the bell housing and all the related clutch linkage.
Sarge01
Oct 2, 2015 09:24 PM
Nose is
Jun 5, 2015 03:56 PM
TomF25066
Oct 22, 2014 12:05 PM
The Boss
Oct 14, 2014 02:25 PM
Alaskan66
Sep 10, 2013 02:45 PM
