1995 Engine Compatability
Old May 6, 2015 | 05:50 AM
Walleye Hunter's Avatar
Walleye Hunter
I have found a reasonably priced 1995 engine. Is there anything on that motor that would be compatible with my e99? If so, what? Even some parts might make it worth buying.
Thanks,
Mark
Old May 6, 2015 | 09:18 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I can't speak for the 95 engines, but from what I understand a 1997 engine is very compatible with a few parts swaps.
Old May 6, 2015 | 11:17 AM
Walleye Hunter
I'm hoping that the block, heads, turbo,crank and cam are at least the same. Forged rods and injectors would be a plus. And exhaust manifolds too.
Old May 6, 2015 | 11:39 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Give us a call and we can go over it with you.
Old May 6, 2015 | 02:58 PM
Toreador_Diesel
Yeah, call this guy^^^^
He'll get it all straightened out and help you make your 7.3 run at it's best. Ask me how I know
Old May 6, 2015 | 05:48 PM
Walleye Hunter
Called and talked to Clay. It sounds like it would work with some stuff swapped out or make a great parts engine. I'll take a look at it and might have the stuff that doesn't match for sale.
Old May 6, 2015 | 07:00 PM
Bonanza35's Avatar
Bonanza35
Can you share more on this.
Old May 6, 2015 | 08:32 PM
Walleye Hunter
I'm not sure what you want to know but if I don't cover it let me know.
Block, cam, crank, heads, oil pan and driver's side exhaust manifold the same. Forged rods. Smaller injectors but cores are good and the right ones for mine will fit right in. Turbo and HPOP are different. I'm looking at exhaust manifold and heads in particular as they can crack and having to buy one when you need it can be hard to find and costly.
Old May 7, 2015 | 08:54 AM
Bonanza35's Avatar
Bonanza35
Thank you, that's what I was thinking also. Just wanted to make sure.
Old May 7, 2015 | 11:42 AM
fordpride's Avatar
fordpride
To use a 94.5 or 95 engine (the correct way) you'll have to take it down to a long block and swap all parts over including front cover
Old May 7, 2015 | 06:04 PM
Walleye Hunter
Yes, Clay also mentioned the front cover
SleeprLegend
Sep 5, 2017 07:55 PM
factory594x4
Nov 2, 2006 06:22 AM
cobra351
1983 - 2012 Ranger & B-Series
Feb 15, 2005 07:23 PM
Fordication
Jun 18, 2004 10:12 PM
