Engine advice- Little spicy
Old Aug 10, 2015 | 10:17 PM
Shadow944795's Avatar
Shadow944795
Originally Posted by oldskool92
That's the problem.... the 35-255-5 camshaft is a flat tappet camshaft.... I have a roller lifter engine. I must have read wrong as I had assumed from that post that I did NOT have a roller engine and therefore NEEDED a flat tappet camshaft..... I need a roller camshaft as my engine is roller otherwise I need to install longer pushrods and from what I read going back to a flat tappet is a step backwards.....
Don't quote me on this but i swear I read somewhere that you can use a flat tappet cam with roller lifters and it will be fine but not vice versa.
Old Aug 10, 2015 | 11:15 PM
oldskool92's Avatar
oldskool92
I don't think you can do that. I think the profiles on the lobes are cut differently to allow solid lifters to rotate in their bores.
Thanks for the help guys. I am so inexperienced with V8 and I should have asked more questions instead of assuming..... I appreciate the help.
BURNSTOUGHFORD
Jul 19, 2012 05:57 AM
USMC0351fordtruckin
Mar 12, 2011 02:51 PM
coreyp
Feb 19, 2011 10:51 AM
pipman76
13
Jan 4, 2010 08:53 PM
Brettddglas
Jun 23, 2004 08:31 PM
