262 tune up
Old May 5, 2015 | 11:47 AM
MichiganLarry's Avatar
MichiganLarry
262 tune up
Hey guys. I am heading out to San Diego next week to visit my son and our 64 Slick. It has a 262 and three on the tree. He says it doesn't want to idle below 900 or so rpm without wanting to stall. I am packing my timing light and he has tools. Our plan is to install a pertronic II ignition, set the timing (need to know what to set it at), check for vacuum leaks and possibly rebuild the carb. The best pic of the carb he could send looks to be a Holley model 1960. My questions are is this the right carb for this engine? What should the timing be set at with vacuum advance disconnected? Should I set the valve lash?
Also on a different note. He installed new motor/trans mounts a couple weeks back. He lifted the truck with a floor jack under the front axle. Now he says the truck is leaning towards the passenger side by a couple inches. Broken spring or is it possible the shackle has turned upside down?
Thanks for your thoughts and advise.
Old May 5, 2015 | 04:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Original 1964 F100/250 262 I-6 carb was an Auto-Lite (Ford) 1100. 262 carb used the same carb kit as 223 I-6 1100.
Old May 6, 2015 | 02:09 AM
OldFords4Life's Avatar
OldFords4Life
Valve lash shows .019 intake and same for exhaust. At operating temperature. Or hot we call it. Timing only says 2 degrees advance @500 RPM. At my altitude 4400ft we set a couple few degrees more, depending. Always disconnect and plug distributor vac line first. I would definitely set the valve lash, because as the valve and seat wears they seat deeper which lessens the clearance so the valve can overheat and burn. Buy a vacuum gauge for tuning, and have fun.
Old May 6, 2015 | 06:58 AM
MichiganLarry
Thanks guys. Just to be clear I hook the vacuum gauge to any available port on the manifold and tune for maximum vacuum?
Old May 6, 2015 | 07:15 AM
Tedster9's Avatar
Tedster9
Yep any port off the manifold will be constant vacuum.
Old May 6, 2015 | 07:17 AM
MichiganLarry
I have been looking this morning for an Autolite 1100 but all the ones I find say for 170-200 engines. The jetting would be wrong on this correct?
Old May 6, 2015 | 07:44 AM
NumberDummy
The 1100 carburetor kit is the same 170/200/223/262 (C8OZ-9A586-D / Motorcraft CT-207A). The jets are different part numbers 170/200 vs 223/262.
170's were installed in Econolines & Bronco's. 200's (introduced in 1964), were only installed in cars.
Old May 6, 2015 | 08:01 AM
MichiganLarry
Thanks ND. Does your part book say what jets the 223/262 carbs take?
Old May 6, 2015 | 08:18 AM
NumberDummy
Left: 1964 F100/250 262: Parts lists 9B & 9D / Right: Jets are 9533.
Old May 6, 2015 | 09:58 AM
MichiganLarry
Thank you sir!
Old May 6, 2015 | 10:02 AM
MichiganLarry
Could you check one more thing for me to see if the 223 uses the same jets. I did find a carb for that engine.
Old May 6, 2015 | 10:08 AM
NumberDummy
I already looked when I posted the pics in post 9. Same C3TZ-9533-D .. #67F Jet = 0-5,000 ft.
Old May 6, 2015 | 10:53 AM
MichiganLarry
So I should be good to go. Thanks again for your efforts.
flashover604
Dec 19, 2009 10:46 AM
77 Bronco
28
Feb 19, 2009 03:13 PM
thamarkman
Mar 17, 2007 12:42 PM
Hellbore
May 24, 2006 10:31 PM
skips69
Apr 5, 2003 03:03 PM
