new ford
Old May 4, 2015 | 03:59 PM
Brittany Brabant's Avatar
Brittany Brabant
new ford
Im not sure where to post if i have a question regarding my 2010 ford f150 it has a 6" lift on 35's. The problem i have is while going around corners the traction control kicks in and starts braking. if i slow right down around these corners it doesn't happen but i have been in other fords around the same corner going almost double my speed and it doesn't engage on their trucks. i have tried holding the traction control button i can get it to blink when its in park but it doesn't shut off(usually it says advance trac off but i haven't seen that on my dash). Maybe theres another way of shutting it off?
Because of the bigger tires i know my speedometer is out I'm not sure if that will need to be reset in order for it stop engaging?
thank you
Old May 5, 2015 | 03:48 AM
Zip's Avatar
Zip
First off welcome to FTE. I would post your problem here. You should get some ideas/answers in a short time.
2009 - 2014 F150 - Ford Truck Enthusiasts Forums
Old May 6, 2015 | 09:19 AM
1Aauto's Avatar
1Aauto
Former Vendor
welcome to the site
Tony
Old May 7, 2015 | 11:19 AM
brandonrr's Avatar
brandonrr
I know this is completely apples to oranges, but may be worth a shot.
Before I got into trucks, I had a 2011 mustang GT that had similar issues when I had bigger tires put on it. I bought it with aftermarket 20" rims that had very low profile tires and when it was time for new tires, I went with a larger size on the same rims. going around turns a little fast or accelerating hard would give me the same symptoms you are experiencing. I had also not had the speedometer recalibrated
I ended up disconnecting the battery for an hour to reset the computers. After I started it back up, I drove the car very easy city driving for about an hour and it seemed to fix the problem. I didn't have any issues after doing that, besides the speedometer reading a little low on the highway.
It may or may not work for you, but it's a very easy thing to try that only costs you some fuel. I recommend trying that first, but again, apples to oranges.
also, welcome to the site. I just joined recently, but have been lurking these forums for months. There are a lot of very knowledgeable people that have some great information.
cyretired2
New Member Introductions
May 4, 2017 10:59 AM
helifixer
34
Jan 6, 2006 01:29 AM
dono
19
Dec 3, 2003 08:40 AM
BigBlueBeast
61
Oct 16, 2003 09:29 AM
kbcapecod
Aug 12, 2003 01:18 AM
