ScanGuage II causes issues
Old May 4, 2015 | 02:35 PM
SBP's Avatar
SBP
Question ScanGuage II causes issues
Ok, I'm new to this sight and working on diesel vehicles beyond the basic care.
I finally got time to work on Blue, my 2007, F250, 4x4 that is my work truck. I purchased as SGII as it looked like a totally awesome tool...BUT, when I use it, I have all sorts of engine trouble. It causes stutter and the engine to die as if I turned the key off. I can restart instantly and then it dies. If it will continue to run it misses and sounds like crap with intermittent bouts of running ok. Unplug SGII and she purrs like a kitten.
I have an old Juice Attitude installed. The SGII takes away all readings on it except for the Juices EGT sensor.
What gives?
Thanks in advance.
Old May 4, 2015 | 02:46 PM
WatsonR's Avatar
WatsonR
Sounds like they are not compatible.
Old May 4, 2015 | 02:51 PM
SBP's Avatar
SBP
My thoughts, but could find no info nor anyone having problem.
Thank you.
Old May 4, 2015 | 04:07 PM
69cj's Avatar
69cj
Never heard of this before. Do you by chance have a bent pin that could be shorting?
Old May 4, 2015 | 04:23 PM
silverbullet6oh's Avatar
silverbullet6oh
X2
Have you contacted Linear-Logic?
1-888-433-5664
Mon - Fri, 8am to 4pm, MST
Old May 4, 2015 | 05:31 PM
SBP's Avatar
SBP
As to bent pin. Can't find anything on either end out of shape. SG and cable work perfect on the other 07 that I just tried it on.
I have not contacted anyone yet. It appears it is incompatible, although not sure why if they seem to work with other tuners. That is my kind of luck.
Old May 4, 2015 | 07:57 PM
WatsonR's Avatar
WatsonR
If you can, remove the juice and try again to prove the point. I'm not sure how the juice connects, piggyback?
Old May 4, 2015 | 08:21 PM
SBP's Avatar
SBP
It attaches to the computer control panel, all the blocks by the drivers side battery. It's a pile of wires and connectors. PITA....
Old Jul 27, 2015 | 01:01 PM
Agent99's Avatar
Agent99
SBP, did you ever get resolution to your issue with the ScanGuage II? I am having some issues that appear to improve when I unplug the ScanGuage II so I am very interested in what you found out.
Old Aug 6, 2015 | 08:15 PM
SBP's Avatar
SBP
Agent99
No, I ended up removing the Edge Juice Attitude and using an SCT X4. Problems solved.
Wish you better luck.
Old Aug 6, 2015 | 10:19 PM
Restlesswildman's Avatar
Restlesswildman
I was going to say that you can not run 2 monitoring systems on the OBD2 plug at the same time with a y connector. I tried that with a buddy's Edge to compare readings between the 2 gauge systems.
Old Aug 13, 2015 | 01:45 PM
Freskan6.0's Avatar
Freskan6.0
I'm just throwing in something I came across with a ScanGuage, I have one for my 04 6.0 and was goon a trip with my son. We took his truck also a 04 6.0 and towed my 12,000 lb toy hauler. The truck was normally tuned with an Sct canned tunes so put it to stock and plugged in the ScanGuage and off we went, it was running a little hotter than normal for the conditions and I noticed a lot of coal from the exhaust, and power was more than normal. I'm sure it had been returned to stock but I double checked and it was stock. Kept driving and going up a small grade it gets hotter then it's supposed to be. Pulling the battery off and waited for a bit and hooked it up ran normal. I tried the same over and over. Now stumped for all intentions the ScanGuage was tuning it. I called Tec support and told the about it and they said impossible. They sent an updated cable and it's not happening anymore. So you cable might be older and short something inside causing the problem. I think my sons has a program in it that's activated by obd port being shorted. Long story but I would get the updated cable and use the ScanGuage it's a great tool.
jaymcjay
48
Sep 11, 2016 08:58 AM
milkman22
May 12, 2014 11:15 AM
gpaslay
Electrical Systems/Wiring
Jan 16, 2007 09:10 AM
xmot
Apr 19, 2006 12:55 PM
NMRancher
Jan 8, 2005 02:16 AM
