timing chains??
Old Jul 27, 2003 | 08:01 PM
gskjolda's Avatar
gskjolda
timing chains??
Hello all,
Rebuliding a 76 360 and have heard that there are different chains based on year to advance or retard the timing. Is this true and can I tell what i just purchased.
thanks in advance
Old Jul 28, 2003 | 12:01 AM
dinosaurfan's Avatar
dinosaurfan
timing chains??
Yes it is true. Most (ALL ? ) of the chains for 72-73 or later are retarded. A set of chain and gears for a 70 model will give you straight up timing. I don't know if you can tell them apart by looking. DF
Old Jul 28, 2003 | 12:18 AM
Putt's Avatar
Putt
timing chains??
You can't tell by looking at them unless they are side by side. The dots are slightly diff position, but hard to tell. You could just by a perf. set with several diff keyways and degree the cam.
Old Jul 28, 2003 | 07:20 PM
lilpig88's Avatar
lilpig88
timing chains??
i think the earlier models were 4 degrees retarded. i tried to change my timing set when i rebuilt my motor, but the parts stores only listed the newer 4 degrees advanced timing set for all years. i found aftermarket sets with 3 keyways on the crank gear was the best way to go.
Old Jul 28, 2003 | 07:59 PM
Putt's Avatar
Putt
timing chains??
The newer sets are 4 deg retarded-for emissions help(won't help on an FE!!). The early sets for thru mid 60's should be straight up- not retarded or advanced.
Old Jul 30, 2003 | 09:04 AM
William's Avatar
William
timing chains??
Cloyes true roller chain set in the straight up keyway.
Old Aug 1, 2003 | 08:26 PM
Putt's Avatar
Putt
timing chains??
Any of the camshaft man. should have a set. Hope this helped.
Old Aug 5, 2003 | 07:44 PM
gskjolda's Avatar
gskjolda
timing chains??
Hi again
still looking for the timing set. I have found the zero "sets" but
I cannot find one that works with my two piece 76 fuel pump ecentric. The earlier sets have a different hub on the cam sprocket to work with the one piece. So I guess now the question is can I use an earlier fuel pump ecentric on the engine. All the "race sets" i have seen advertise list them fitting all the years so it looks like going to the earlier setup is expected or they do not think about the difference. hey guys thanks for the help already given.
Old Aug 16, 2003 | 10:42 PM
gskjolda's Avatar
gskjolda
timing chains??
I purchased a sealed power set and when comparing it with the my orginal set against the engine I see that the new set has the cam timing one tooth advance. So it appears that I am in the money. I did not find any info anywhere stating the my newly purchased was advanced.
