D1VE-AA block bore max???
Good day all. I just picked up a D1VE-AA block with the letters E3 and M15 stamped in the lifter valley. I've spent the last few hours reading threads to try and find my answer.
I was told this was an original unmolested block but when I used my cheapy vernier caliper to measure the bore, I did the math wrong and assumed that it was a stock bore (4.36"). When I got home, re measured and re did my math I now have a bore that is 4.39" which I believe is .030 over? The caliper read 4" and .63-16ths, for any of your math whizzes. I'm pretty sure I take the .63, and convert it to 6.3 and divide by 16ths to get the inches. 6.4/16 = 0.394" plus 4" = 4.394" bore size.
The cylinders are not in great shape and will likely need to be over bored to bring them back. I'm seeing older information that sais I can only go to .030" and that's it. Then other threads are stating .080" over!?!
HELP!!! I'm very concerned that I just bought a $300 boat anchor. This purchase also came with a 429 crank (stamped 4U I think???) and 429 rods and pistons and original D0VE-C heads. I was hoping to make this a mild big block for my Model A. Any help would be appreciated to clear up this confusion.
Thanx!!!
Travis.
Thanx!!!
Travis.
Hey Krooser, Thanx for the reply. An update is in order.
I borrowed a good quality inside micrometer, and it turns out the bore is 4.361". So stock! I'm very excited. Now to do some research to find out if I should be looking at making this a 4 bolt main or is a 2 bolt good enough. I read hear that a 2 bolt is plenty good enough up to 900hp? This block will definitely need a cylinder bore and line bore. Any thoughts are appreciated.
Travis
Travis
Laundry list of mods for increasing power. Serving suggestions:
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
Green_Monster
Jan 5, 2010 12:00 PM
Thomsen
Jul 19, 2006 02:44 PM
chrono4
Nov 10, 2005 12:21 PM
XB_Aust
Aug 9, 2005 05:13 PM
tess100
Jan 6, 2004 08:55 PM
