need technical help with power fold mirrors
I'm trying to get this set up on my dad's truck, but the passenger side door harness is on backorder. The driver's side harness is off from a 2014, so it's possible the plugs don't match up to the switches. Any insight or further explanation would be appreciated. By the way, according to the dealer, '08-'10 door harnesses are obsolete.
Just so it's clear in my ADHD mind, you added the wires/pin pigtails to the cab harness under the dash near the headlight switch and ran the wires to the relay?
On the passenger side you added the needed wires for the stock door harness which plugs into the mirror connector on one end and on the other end into the molex connection between the body and door? From there, the body harness contained the proper wires?
I have already added these mirrors to my 06 King Ranch, but I didn't have to mess with the Molex connection. I've read where guys have drilled out empty spots and run wiring directly through the connectors, but I don't want to risk screwing that up.
I have already added these mirrors to my 06 King Ranch, but I didn't have to mess with the Molex connection. I've read where guys have drilled out empty spots and run wiring directly through the connectors, but I don't want to risk screwing that up.[/QUOTE]
OK let's try this again. On my truck, the factory wiring in the dash included the harness for the relay, but that wiring went to other places other than the cab harness door plugs. So I simply cut the wires for the mirror functions on the relay harness, and spliced on my new wiring. I had to make up the pins on both the door harness and the cab side harness plug. The nice thing with the older trucks, is they didn't use these cab/door plugs. It was just a hole in the door with a flexible conduit. Definitely easier. But I wanted to keep it factory looking. If you already added them to an 06, the install is really the same, except for the molecular connectors.
OK let's try this again. On my truck, the factory wiring in the dash included the harness for the relay, but that wiring went to other places other than the cab harness door plugs. So I simply cut the wires for the mirror functions on the relay harness, and spliced on my new wiring. I had to make up the pins on both the door harness and the cab side harness plug. The nice thing with the older trucks, is they didn't use these cab/door plugs. It was just a hole in the door with a flexible conduit. Definitely easier. But I wanted to keep it factory looking. If you already added them to an 06, the install is really the same, except for the molecular connectors.[/QUOTE]
I see. I assumed all 2008s had the molex connectors as someone with an 07 said they had them too. I guess I can wait for the new passenger harness or get a wiring diagram from the dealer. I assume the parts department or should I ask my technician buddy? Thanks for your help clarifying. Unfortunately I struggle with this on most everything.
[/QUOTE]Don't stress over it. I went over the wiring diagrams and pictures from other installations for over a year before attempting this. The molecular connector on the door and cab had me nervous. But I studied the wiring diagrams, wrote everything down in a note book as to wire colors and pin locations. The passenger side on my truck was really only 4 wires that I added for the telescoping and folding functions. But if you have memory functions on your truck, that is a little different. Check eBay if you can't get a new harness for the passenger side. I actually have a brand new passenger side harness for an 08 with memory for sale. I bought it thinking I could use it, but pin locations were different, and I didn't want to mess it up by moving them around. And it was to late to return it to Tasca parts. I'll send the info I have this week. I just have to find some of it on my computer.
