300 build
there are a number of 300-6 specific forums where guys are putting out good power from that motor. doing it cheap is the challenge for most. Cam, header, intake + 4brrl will be a must. Your still going to need gears in the front/rear diff regardless to compensate.
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
The nice thing about the 300 is that it's so restricted stock that it doesn't take much to wake it right up.
Intake:
Offenhauser C or DP, or a Clifford intake.
A mid-small 4bbl. I'd recommend a 465cfm Holley or a 500cfm Edelbrock.
The 390cfm Holley will also work well.
You CAN use a 600cfm (I have one on one of my 300s), but they're a touch big and you start to lose some low end. But, they work, and can work well.
Exhaust: Headers are good, but you can also suffice with some manifolds from an EFI engine. They're robust, cheap, made by Ford, and offer a great improvement over stock.
Run a 2.5" single exhaust out the back.
The NP435 is the transmission you're looking for. They're super robust, so often just finding one in a junk yard (most often behind a 300) and filling it with fresh oil is about all you need. Note that you'll need a different floor pan and floor mat as the hole placement for the shifters are in a completely different places. That SROD aluminum highway transmission that's in there now is a piece of junk.
New Process 435 (Rebuilt) Transmission-Broncograveyard.com
(They have their info wrong on the years. They used them until the mid-late 80s)
For 33" tires and a non-overdrive transmission, you'll probably want to stick with 3.50 gears front and rear. That'll put you around 2100 RPMs @ 60mph and give you plenty of oomph. If you're more into off-roading and don't plan on much highway, go with 4.11s.
If you change your tires and gears, be sure to reset your speedometer. It's cheap and easy to do.
If you're rebuilding it, look into a performance cam. A Comp 260 is a common choice. The 252 is more for a mild/econo build, and the 268 is more for a higher HP/aggressive build, so pick your end of the spectrum.
If you want to put a bit more into it, install oversized valves and get the head port and polished.
You'll have plenty of engine after that.
