Sponsored by: Real Truck
Upper engine oil leak
Old May 2, 2015 | 11:35 AM
cferrer56's Avatar
cferrer56
Trying to help a friend who has a 2000 Super Duty 7.3L Diesel Power Stroke. 300,000 miles and having an oil leak around top of engine near turbo. It's losing oil at a rate of half a quart every two days. Driver says that engine lacks power. Is it time to replace turbo? What else should I look for concerning the oil leak. Also, what else should be replaced/inspected while replacing turbo?
Old May 2, 2015 | 11:44 AM
airm4n's Avatar
airm4n
Hopefully not but most of my diesel engine experience is on equipment and semis. Generally when you are getting oil leaks in the turbo it means the oil is getting past the liners and plugging up your charge air cooler. I would get a very good mechanic to check it out. Is the engine smoking bad when he throttles into it?
Old May 2, 2015 | 03:15 PM
cferrer56's Avatar
cferrer56
Thanks!
No, there is no smoke coming out of the exhaust. In fact what oil is visible on top is also very little.
Nick_A_44663
Dec 24, 2009 07:36 AM
rckrwlr
Feb 22, 2007 11:46 AM
Ed the outdoorman
Oct 4, 2003 08:06 AM
Bugtussle
Oct 17, 2002 06:27 PM
bisaksen
May 20, 2002 12:09 PM
